Home > Td5 > Replacing sunroof seal |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 898 |
2nd row seat sunroof in not a standard Land Rover thing... as for removal, just pull the felt/rubber inside trim piece (item 5) off, start at the handle that is where it joins. You should be able to do it all without pulling the roof liner.
Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
28th Feb 2019 11:31pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5736 |
Cheers. I have not seen another one with the same sunroof as mine. From what I can tell it is a standard LR item but in the middle.
I shall have a look over the weekend before I spend £70 on a seal. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
1st Mar 2019 9:09am |
If it is the seal to the glass, you can do it all in situ. Pull the glass out, stand up inside and pry out the seal. It is a PITA to do but if you get the right tools and some silicone spray to mAke it easier, it’ll work.
Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
1st Mar 2019 5:04pm |
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 305 |
id love to see a picture of your install over the seconnd row seats...sounds interesting. Patrick |
2nd Mar 2019 9:51pm |
That’s funny I have thought about doing that to mine as well but decided it was too much work 😂. I too would like to see that. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2nd Mar 2019 9:55pm |
PaulE Member Since: 29 Apr 2020 Location: East Sussex Posts: 4 |
Here's another solution for those of you with a leaking sunroof, and yes it works. You'll need to purchase 3mm to 5mm thick perspex either clear or tinted (eBay), slightly larger than the existing sunroof, some clear bonding sealant and be handy with either a jigsaw or a fretsaw. Take out and strip existing Sunroof, mark outline onto perspex and then cut approx 5mm within that around the outline including the fixings and clamp mechanism. Check 5mm is enough, the idea is to compress the existing seal down when bonded to the glass roof, so it needs to sit on the seal but not the seal frame. Once cut, assemble and re-position in roof to make sure the roof seals and there are no clashes with existing fixtures. When happy fix perspex to glass using the sealant adhesive. It works, and although makes the sunroof stick-up 3-5mm more does not increase wind noise, not that you'd hear that anyway.
29th Apr 2020 11:01am |
Sorry missed your post. I will nip out when its not raining and take some pics 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
29th Apr 2020 1:44pm |
As requested.
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge I replaced all the seals with new ones and new hinges. I had to add some rubber foam sponge stuff to seal the rear edge (The side where the latch is) as the glass has a curve to it, the glass and seal would not sit together and left a gap. Even with the latch tightened up as much as I could. I tapered each end of the foam to try and match the glass. Lots less in the way of leaks, but still the odd sneaky one appears. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
29th Apr 2020 2:56pm |
ijefferyes Member Since: 11 Apr 2020 Location: Radstock Posts: 35 |
Can anyone tell me the part number for just the rubber seal on the sunroof with the twist handle?
All I seem to be able to find is AWR3321 according to lrworkshop. https://www.lrworkshop.com/parts/AWR3321 But this appears to be the whole frame and it is £470. Cheers Ian |
29th Apr 2020 10:11pm |
That is the right number, never seen the rubber separately
https://www.lrworkshop.com/diagrams/land-r...roof_44895 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
30th Apr 2020 12:19am |
https://www.ebay.co.uk/sch/i.html?_from=R4...p;_sacat=0
And then I bought https://www.ebay.co.uk/itm/LANDROVER-DEFEN...SwjDZYmbaJ Not sure exactly which item number you are after for you sunroof but on Ebay there is: https://www.ebay.co.uk/itm/GENUINE-LAND-RO...SwgLFelwlF 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
30th Apr 2020 8:13am |
