![]() | Home > Td5 > Picture of Rear seat belt mounting in 90 |
Green&Gold Member Since: 13 Oct 2014 Location: Surrey Posts: 7 ![]() ![]() ![]() |
hi mark13
I came across this v useful link which contains a portion on the modification I think you are after. The PDF can be found here: https://www.defender2.net/gallery/albums/u...ersion.pdf |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 ![]() ![]() ![]() |
Check out the thread about insurance cover in this section...be worried, be very, very worried
mark13 Member Since: 16 Apr 2018 Location: Essex Posts: 56 ![]() ![]() ![]() |
Thank you for the reply’s but I don’t think the link works, it just comes up with the link can not be found.
Insurance is something I’m very interested in when I spoke to the insurer (Aviva) they said as long as the seats count is below 6 and installed to the manufacturer spec they are fine with it |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1457 ![]() ![]() ![]() |
Declare the seats as a mod and they should be fine. A plan are and no extra charge in premium. There's a designated bracket that fits in the corner, which carries the reel and top mounting.
these are the kiddies ![]() Eddited to add sorry Ive not got any pictures. I used genuine parts other than the arch plates. passed another MOT Saturday and hes was more than happy ![]() |
mark13 - apologies try this...
Orangesofa Member Since: 10 Oct 2014 Location: Somerset Posts: 214 ![]() ![]() ![]() |
From Exmoor Trim. If I recall correctly it's a genuine LR part.
![]() Click image to enlarge ![]() Click image to enlarge Phil |
Scrawf Member Since: 24 Jul 2016 Location: Matlock Posts: 25 ![]() ![]() ![]() |
On mine there is a bar under the wheel arch that the bottom of the seat belt bolts to through the floor. It’s attached to the rear bumper inside the rear wheel arch. I guess the floor itself wouldn’t be strong enough to retain the seat belt in the event of an accident so Land Rover reinforced it with a bloody great bar attached to the bumper / chassis! It’s a pig to get in and out! I know cos I fitted rear wheel arch liners and the bar had to be removed and then reinstalled to get them in.
Hope this helps? Scrawf |
Piggle Member Since: 24 May 2015 Location: Surrey Posts: 83 ![]() ![]() |
I have the exmoor trim fwd facing rear seats fitted in the back of my TD5. Disclosed to my insurer (NFU) and no problems at all.
petegoss Member Since: 19 Nov 2020 Location: Wolverhampton Posts: 7 ![]() ![]() |
Any pictures of how you fitted the seat belt buckle (to the floor I assume? |
It was integral to the seat... Phil
No help but thanks Phil, you must have the chamfered wheel arches
I don't actually - it is a van back with self cut windows, so square-edged arches.
I installed the loc and fold (earlier model) which has the buckle receiver attached to the seat rail. I'm not sure what the situation is nowadays but back then it was the only type approved one which would be insurable per se. This pic is of current version of what I have. ![]() Click image to enlarge Phil |
