Home > Td5 > Oil inside Intake Manifold |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4784 |
When I removed mine recently (about 125k miles with EGR removed from about 60k miles) it was clean as a whistle so I would suggest you have a problem somewhere.
Maybe crankcase breather valve failed or turbo leaking oil into the high pressure side of the compressor? 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
25th Feb 2019 2:36pm |
JayPeeEss Member Since: 30 Mar 2013 Location: Cheshire Posts: 30 |
thank you for the quick response and confirmation of my thoughts.
The breather hose on mine does look a mess on the outside, but I didn't spend the extra five minutes to check inside and see what state it was in - so will add that to the list. Fingers crossed I don't have a major issue.. Cheers Defender 90 - Tomb Raider LE Discovery 5 HSE - yes, even despite the ugly backend. Range Rover 4.2SC - Gone and still being missed |
25th Feb 2019 3:25pm |
Click image to enlarge Click image to enlarge Just as a follow up to this original message. I finally got around to cleaning it and other than causing a heck of mess and stinking of degreaser for the next few days the clean out has made a real difference. State of the manifold was as bad as described - full coated in oil. Following a few rounds of cleaning - it came up a treat and on replacement has meant a real difference in smoke (now almost gone) and the flat-spot under acceleration looks to have disappeared also. Really not that difficult to do -just a pain for the mess and you need tiny-hands to get to some of the bolts. I also replaced the breather hose with a new one and both have stayed clean following this work. Cheers Defender 90 - Tomb Raider LE Discovery 5 HSE - yes, even despite the ugly backend. Range Rover 4.2SC - Gone and still being missed |
30th May 2019 4:11pm |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4395 |
A few years ago I used a can of 10K Diesel on a 300TDI that had a severe oily problem, could just about get my little finger in the intake that's how bunged up it was. 10k Diesel cleared it all out (intercooler and all) perfectly.
https://www.autoparts.uk.com/10k-boost-pow...?MSCheck=1 Might be worth a try. |
30th May 2019 4:29pm |
Cheers geobloke - i've not seen that before and will definitely try it if it gets bad again.
Certainly trying to jet-wash the manifold out with gunk and hot-water made a terrible mess and got me a huge clean up job. Defender 90 - Tomb Raider LE Discovery 5 HSE - yes, even despite the ugly backend. Range Rover 4.2SC - Gone and still being missed |
30th May 2019 4:32pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16871 |
Dishwasher job, I reckon.
30th May 2019 6:36pm |
Re: Dishwasher - that was my thought also but was persuaded by the impending pain i would likely get from the other-half if / when she found out. Not worth the grief... Defender 90 - Tomb Raider LE
30th May 2019 7:51pm |
Yes, you need to keep the dishwasher's weekend job a secret from the Domestic Authorities.
30th May 2019 8:59pm |
windy81 Member Since: 14 Mar 2018 Location: North Wales Posts: 311 |
30th May 2019 9:38pm |
