![]() | Home > For Sale & Wanted > [For Sale] Wide track Sankey |
DOOFER Member Since: 07 Oct 2012 Location: Suffolk Posts: 412 ![]() |
tempted, but how easy is it to change it to a civilian ball hitch? DON'T PANIC
Nevillerover Member Since: 14 Feb 2015 Location: Suffolk Posts: 224 ![]() ![]() ![]() |
No idea. Apart from a military 90 I had, all my landys have had adjustable Dixon bate type hitches and I simply used a combined NATO and ball hitch. It's like a NATO but the bottom half is also a ball. They don't rotate like a NATO but on the road or flat dirt that is fine, never had a problem.
Whilst nothing is impossible, it's not straightforward as it requires a fair degree of fabrication. It's not a simple nut and bolt job.
Which version of the wide track is it? The MkIII (disc braked version) requires a rotating NATO hitch but the earlier MKII needs a fixed hitch. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
It needs a rotating hitch but fixed is OK on road or flat ground. Easiest solution is to buy a suitable hitch.
Now on eBay.
