![]() | Home > Puma (Tdci) > Tightening torque for differential flange bolt |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2511
100 Nm. I believe it is FS112306P Puma 110" SW
| Vogler Member Since: 02 Nov 2014 Location: Brussels Posts: 309
The tightening torque is mentioned on Ashcroft's YT video on diff assembly at 8:00.
If bolt: 100Nm, if nut 129Nm. Just stumbled on it a couple of days ago. Greetings, Joris Antares Treadwell, a MY06 110 Td5 in Chawton White |
Lastly, apply lots of high strength loctite. Puma 110" SW
| Harald Member Since: 30 May 2012 Location: Flanders Fields Posts: 81
Thank you all. Just couldn't find this information in the workshop manual.
I haven't been able to find any manual at all for the rover diff. All info I found came trough others e.g. Ashcroft, LRTV...
J Antares Treadwell, a MY06 110 Td5 in Chawton White |
| BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 403
See https://www.landroverweb.com/Pdf-files/Man...nual-3.pdf for the manuals ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18040
It is quite hard to find differential overhaul information in the current LR manuals.
The Puma WSM covers the removal and refitting of the diff, and the replacement of the pinion oil seal, but not the overhaul of the diff (probably because dealers now simpler swap them out, and don't overhaul them). I don't know if it is still the case, but the the 2.4 Puma WSM used the rear axle chapter from an early TD5 WSM and makes no mention whatsoever of the P38 diff fitted to LWB vehicles, it assumes that every rear diff is a Rover-pattern diff. Incidentally the WSM does not instruct you to use thread locker on the pinion flange bolt, just to tighten it to 100Nm. The only recent-ish manual I know of which covers the Rover pattern two-gear diff and the P38 four-gear diff as used on LWB Pumas and late TD5s is the last of the TD5 manuals covering models up to 2006, which is not available electronically (it might be if you have a TOPIX subscription, that I don't know). If you want a copy you'll have to buy it in paper form. It is the ONLY manual I have ever found which covers an overhaul of the P38 4-gear diff. The earlier TD5 manual (which is widely available on the internet) does not cover the P38 diff. https://www.amazon.co.uk/gp/product/185520...le_o06_s00 Last edited by blackwolf on 3rd Mar 2019 8:26am. Edited 1 time in total |
| neon1991 Member Since: 26 Mar 2018 Location: Colchester Posts: 101
I second the thread locker... I had one come undone (probably nothing to do with lack of threadlock) and it was not a fun experience. ruined the flange, seal and uj. sounded like bricks in a cement mixer... at 70mph
The manual may not say to use thread locker, but it cannot possibly do any harm.
| All times are GMT |
