Home > Defender Celebration Series & Classic Works > Defender Heritage paint code
nidge n
Guys, the wheels on my Heritage are in need of attention, the paint depth on the wheels is pretty poor, showing a little surface rust. My Dealer has offered to exchange them, but the ones they showed me looked equally poor. Frankly it won't take long for the replacement to deteriorate , so i would rather respray my originals. So now I'm trying to find the paint colour and code. Grasmere Green is the metallic main colour but the wheels are a flat paint.
I've attempted a little researched and this is the best i came up with.
https://paintman.co.uk/shop/land-rover-atlantic-green-lrc726/
Post #757913 11th Feb 2019 10:53am
doublea
Scotland 2016 Defender 110 Puma 2.2 Adventure Phoenix Orange
I was about to suggest just that.
The original Heritage colour of Atlantic Green is very close to Grasmere (Paint code 1CD)
Here's the Grasmere, Atlantic and Keswick on mine.
I think the Atlantic is slightly lighter, but the paint is still wet!
The touch up paint has part no STC60747T, but I'm not sure it's still available.
Currently, I'm deciding what colour to paint my new HD wheels; I had thought the later Heritage wheels were the same as the body, obviously not!
My sister had her HD steels changed under warranty. As I understand it, they come primed black, and only the outside is painted, ordinarily. However, the dealership my sister went to painted the replacements in their own bodyshop outside and in; two years later they are looking fine. Current Steeds:
2015 110 UW in Grasmere Green
2003 BMW F650 the Hack
2000 Elise
1992 Ducati 888 (no longer in bits, yahoo)
1990 TDR 250 (in bits again)
1988 TDR 250 (no longer in bits) and for sale
Post #759309 17th Feb 2019 10:53pm
nidge n
Thanks for your help with this one. Cricky, they are as near as "dam it"is to swearing. I wouldn't be surprised if the wheels were originally sprayed Atlantic, they look a slightly different shade but as i just mentioned, too close to call. Interesting to hear your comments on the priming of the Heritage wheels. Removing, respraying properly and refit is the way forward for me.
Thanks again
N
Post #759360 18th Feb 2019 10:20am
doublea
If you like, I'll post the touch up paint to you, then you can do a direct comparison on the wheel? Current Steeds:
2000 Elise
Post #759371 18th Feb 2019 11:26am
nidge n
Thank you so much for your very kind offer. I had a similar thought earlier today and ordered a touch up paint from my local dealer. Your generosity epitomises the camaraderie of this forum. I’ll drop a note once I’ve checked it against the wheels.
Thanks again
Thumbs Up
Post #759505 18th Feb 2019 10:51pm
Sulisuli
Great to see such a nice gesture between forum members, makes you proud to be a part of this forum when people go that extra mile for others, nice one Doublea Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #759506 18th Feb 2019 10:56pm
Huttopia
Thanks again
N
Nige, I had exactly the same problem with my Heritage and eventually (with help from CRC) managed to get the wheels stripped, primed and painted properly as a goodwill thing under warranty. Believe it or not the bodyshop charged about £700 to do the job. The argument for getting it done under warranty was that JLR were unable to provide a set of wheels that were up to scratch - 3 new sets were delivered to the dealer and they were all marked / pitted / had rust coming through.
HTH, good luck.
Huttopia.
Post #759826 20th Feb 2019 6:25pm
doublea
Just wondering if the Celebration Heritage wheels are Grasmere or Atlantic?
I've a set of HD wheels to get painted. Well, actually the paint shop recommend powder coat then lacquer.. Current Steeds:
2000 Elise
Post #768224 11th Apr 2019 11:26pm
UtilityTruck
I had always assumed the wheels were body colour- interesting to hear they’re in fact different. Getting steel wheels painted is a bit of a minefield in my experience, hope you get it sorted 2014 Keswick Utility 2.2
Post #768233 12th Apr 2019 6:37am
xjahx
United States 1997 Defender 110 300 Tdi SW Barolo Black
On a related note, what is the paint code on the white roof? Thanks...
Post #813648 4th Feb 2020 9:23pm
Gravygraham
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Reading the posts above I'm still undecided if the wheels are indeed the same colour as the bodywork. That said, I'm about to have mine stripped and painted in Atlantic Green, and as Nige N suggested, there's next to naff-all difference. I'm waiting to see if my local wheel specialist thinks powder coating would be a better option.
In the meantime, I'll be busy working to bring some sparkle back to my horrid rusty hubs.
 Lucky custodian of several Landies
Post #937237 11th Jan 2022 6:19pm
nidge n
Gents, sorry i should have updated this thread with the results of spraying my wheels. I did go ahead and respray the wheels on my heritage in Atlantic Green. Atlantic is a flat coat and matched the original paint used on the wheels. I would be interested to learn how you went on the the powder coating if that is the way you end up going
good luck Thumbs Up
Post #937253 11th Jan 2022 9:00pm
doublea
Eventually, I settled on a hybrid solution for my HD wheels.
At my local powder coater, I couldn't find a close match using the powder coat RAL codes (closest I though was "Pastel Green" 6019), and because it was an uncommon colour, it was going to be more expensive that the usual price for powder coat.
I found another local company that did a powder base coat, then colour matched spray paint (using metallic Grasmere paint code) then a transparent top powdercoat.
They're still under the bench though, so not able to comment on the anti corrosion aspect yet. Current Steeds:
2000 Elise
Post #937260 11th Jan 2022 10:05pm
nidge n
They look good and a route i may go down as the rust is bound to show itself again on my wheels Big Cry
Post #937266 11th Jan 2022 10:23pm
Gravygraham
That’s interesting . . I never knew painting over powder coating was a thing. Another option for me to consider. Lucky custodian of several Landies
Post #937281 11th Jan 2022 11:46pm
