Home > Technical > centre dash console
Bongo1
centre dash console
Does anyone know of a Defender 300 centre dash console that you can fit without cutting the dash .
Post #759326 18th Feb 2019 12:28am
ibexman
Not unless you get a complete Td5 dashboard
Post #759327 18th Feb 2019 12:36am
donmacn
I haven't the time or internet access to check properly at the moment, but doesn't the Raptor console fit without cutting? I could be wrong, and it's aftermarket, not LR, but worth a quick look to check. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #759355 18th Feb 2019 10:07am
rallysteve
The mud console physically fits over the lower dashboard without any cutting. You just cant fit anything with any real depth to it (i.e. radio, dials or switches) in the lower half without cutting the dash.
Post #759366 18th Feb 2019 10:46am
Litch
"but doesn't the Raptor console fit without cutting?"
No, the Raptor console requires you to cut a section out of the lower dash.
That said, when fitted it is an excellent piece of kit. ONE LIFE, GET IT!
Post #759473 18th Feb 2019 9:27pm
Bongo1
Shame i liked the Raptor with all the order options , But the MUD is ok . i only really want it for the radio up top and a few switches lower section . So perfect if no cutting .
Post #760273 23rd Feb 2019 12:08am
Bongo1
Just checked the MUD console , you do have to cut the dash Sad . You would someone would make one that you dont need to chop the dash up .
Post #760275 23rd Feb 2019 12:23am
Fatbaron
The Raptor dash is a great bit of kit. Can I ask why you don't want to cut?
Post #760292 23rd Feb 2019 9:35am
The whole point of these dash consoles is to provide space that the original dash doesn't but they're only going to work with the original removed.
If you really don't want to cut your dash then you could, instead, fit the earlier radio mount in the space between the vents and add extra switches to the oval recess inthe centre of the lower dash. There are various options for overlay plates for the latter that allow all sorts of switch and gauge combinations to be installed. I think Mud might do them but they're certainly available on eBay.
Alternatively, you could build your own Shocked
 Darren
Post #760305 23rd Feb 2019 10:37am
grafty99
Shocked 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #760310 23rd Feb 2019 10:51am
DSC-off
As above, the point of a console is to fit additional accessories.
If you only want to fit a single radio, the MUD dash has a single position in the top angled face that can be used without cutting the dash. May not be suitable for some CD players that are prone to skipping if mounted at an angle.
I'm sure switches could be fitted in the lower area with careful positioning or short depth.
I was reluctant to cut the dash initially, but the convenience outweighed the concerns.
If it was a pristine, 100% original vehicle I wouldn't do it.
Post #760312 23rd Feb 2019 10:54am
