Home > Maintenance & Modifications > Gwyn Lewis rear mud shield/mud Flap fitting advice.
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
I have had a set of these for a couple of years, not got round to fitting them due ill health, and now that it is warming up finger crossed and SHMBO wanting rid of them I am building myself up to fitting them to the post 2007 110 USW and I'm looking for some advice.
Is the fitting an easy job for one man to do?
Do the rear wheels need to be removed ? Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #759172 17th Feb 2019 11:53am
Rashers
I think they have instructions on their website.
Post #759194 17th Feb 2019 12:50pm
Bluest
Fitting is easy, but it is useful to have a second pair of hand for tightening the bolts that go up through the tub. 2007 110 TDCi Station Wagon XS
Post #759197 17th Feb 2019 1:06pm
I'll second the above and the instructions with the kit are very clear.
I fitted them back in September and you can see the detail HERE. Darren
Post #759203 17th Feb 2019 1:58pm
landy andy
Easy fit, easier with a set of hands inside. Wheels remain on, but I jacked mine up high so rear wheels were hanging down out the way.
Post #759238 17th Feb 2019 6:07pm
ARC99
I have the instructions that were included in the package and a copy from there web site, no mention of removing rear wheels. Don't make old people mad.
Richard
Post #759357 18th Feb 2019 10:10am
ARC99
I see from your posts that you had the same idea of separating/isolating the two metals with rubber, I have obtained sticky backed rubber washers for the same reason and intend to use a marine sealant on the edges of the galvanised brackets to prevent road rubbish collecting in the gap.
I have one observation. The mud flat original or the included replacement is suspended from a bracket on three bolts and does not have a strip that would prevent the edges of the mud flat from bending in the air stream. Don't make old people mad.
Richard
Post #759362 18th Feb 2019 10:27am
I removed the rear wheels just to make life easy for myself. It's not necessary but does give better access. Darren
Post #759363 18th Feb 2019 10:27am
It doesn't seem to be much of a problem, to be honest. With the mud flap mounted on the front face of the bracket, the load is spread across it. Darren
Post #759364 18th Feb 2019 10:32am
