Home > Technical > Puma 2.2 Turbo Inlet pipe problems
British Bulldog
2015 Defender 130 Puma 2.2 HCPU Chawton White
Hi all, had my 130 Defender for 4 years now and only done 40,000 klms however, the turbo inlet rubber tube has split 4 times (and I suspect its gone again), she's just gone into Limp mode which is typical when this happens, the rubber elbow tube connected to the turbo inlet keeps splitting .... is there a factory mod to stop this happening, or an accessory (Heavy duty tube or stainless steel mod /) That can cure the problem ?[size=18][/size] Cheers and thanks for any advice
Post #759126 17th Feb 2019 3:49am
Co1
Would silicon hoses do the trick? I suspect the temperature where you are higher than average, so silicon should give better heat resistance.
Post #759140 17th Feb 2019 8:57am
British Bulldog
A good idea however, the hose in question is custom made to be slightly larger on one end than the other ...
Thanks !
Post #759146 17th Feb 2019 9:56am
