![]() | Home > Puma (Tdci) > Saggy bottom! |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 ![]() ![]() ![]() |
Mine's had HD suspension from new, and from what I've seen when parking it next to other Defenders, it makes no difference to the ride height at all. I don't think it makes the ride quality harsh either, I actually think it's a bit of an improvement on the standard.
I think you're going to have to go down the 'longer spring route'. Pete |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
fit some discover1 sprong isolaters they will give you an extra 10mm to trim the car up
toshers Member Since: 19 Sep 2010 Location: Inverurie Posts: 120 ![]() ![]() ![]() |
Does anyone recommend some standard height HD springs for the rear?
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
all the std 90 xs have heavy duty rear springs (well mine did)
Great to put loads on...but makes the ride harsh (for back seat passengers!!) Mike |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2682 ![]() ![]() ![]() |
Hi Tosher
Also worth a look are the spacers that Gwyn Lewis has. Available as 1 - 1.5 or 2 inch. I fitted the 1 inch all round on my 90. They replace the standard spring seats on top of the axle ( and dont cost too much) www.gwynlewis4x4.co.uk Hope that helps Mark |
These look just the job ![]() |
Matt Member Since: 28 Feb 2011 Location: Aylesbury, Bucks Posts: 180 ![]() ![]() ![]() |
Yeah, genuine LR HD springs ![]() ![]() |
