Home > Technical > Dreaded intermittent power loss
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Recently, my truck has been suffering from intermittent power loss - i.e. limited to 30mph. Was initially for a few seconds only but today lasted a bit longer - like almost a minute.
No MIL light showing but Nanocom reveals the following - could any of these be responsible? The Fuel Circuit ones seems relevant B1A75 - any idea of how to fix it?
FAULT 1 OF 7
ECU: Instrument Pack
CODE:U3000
Control module
(NOT TESTED DTC, PERMANENT)
SYSTEM INTERNAL FAILURE -
CALIBRATION/PARAMETER MEMORY FAILURE.
FAULT 2 OF 7
CODE:B1A75
Fuel sender 1 circuit
GENERAL FAILURE INFORMATION -
GENERAL ELECTRICAL FAILURE.
FAULT 3 OF 7
CODE:B1A81
Internal trip switch circuit
ALGORITHM BASED FAILURE -
SIGNAL PLAUSIBILITY FAILURE.
FAULT 4 OF 7
CODE:U3000
Control module
GENERAL ELECTRICAL FAILURE -
CIRCUIT VOLTAGE ABOVE THRESHOLD.
FAULT 5 OF 7
CODE:P1602
Immobilizer/engine control module communication error
FREQUENCY MODULATION/PULSE WIDTH MODULATION FAILURE -
NO SIGNAL.
FAULT 6 OF 7
CODE:U0401
Invalid data received from engine control module/powertrain control module
EVENT INFORMATION.
FAULT 7 OF 7
CODE:U2101
Control module configuration incompatible
NO SUBTYPE INFORMATION.
Post #746521 19th Dec 2018 10:54pm
kmac
re P1602 - battery is on its way out I think. That could be the cause of this code.
Battery is the original from Oct 2009 when truck was first registered.
Its a MY2010 USW - XS spec 110.
Post #746523 19th Dec 2018 10:59pm
kmac
Also, could a dodgy EGR cause intermittent power loss issues?
Mine has been noisy whilst driving but still does the five chukka chukkas when turning off the engine.
Post #746531 19th Dec 2018 11:30pm
I would say looking at your DTC’s it will be the IPAC.
Record all the codes on paper and keep safe then clear them, before doing this check the connector plug to the rear is secure.
See what DTC’s if any are logged after that.
If there continues to be issues IPAC related, check the solder joints on the PCB and or try another IPAC cluster.
I would doubt the battery or EGR has anything to do with it as you’d get EGR codes or low voltage signal codes.
Also eat in mind the VCV has no MIL or DTC’s that logs when there could be issues there.
That would however, not cause the IPAC issues that are logged DTC’s.
Occasionally poor earthing can cause all sorts of phantom issues too. Like the time my transfer box earth strap was loose and when I would brake or indicate every light would light up like an Christmas tree internally or externally in different mannerisms.
Looking back afterwards it was rather entertaining but certainly not when it started out on the road!
As far as I’m aware the IPAC can be just changed over as all vehicle info is ECU stored. Unless anyone can correct me on this, if so please feel free.
Personally I’d try the easiest cheapest options first. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #746541 20th Dec 2018 12:18am
kmac
Thanks Steve, will check the IPAC connector and take it from there
These DTCs cannot be erased as they are "permanent" ones, meaning only resolution of the error in the relevant module will clear them.
Post #746543 20th Dec 2018 12:30am
kmac
Unplugging and re-plugging the IPAC seems to have cleared all codes except for the following:
FAULT 1 OF 2
CODE:P1602
(NOT TESTED DTC)
NO SIGNAL.
FAULT 2 OF 2
CODE:U0401
(NOT TESTED DTC)
EVENT INFORMATION.
Post #746589 20th Dec 2018 12:40pm
sam7345
Hello, I have all these codes at present and my defender will not start.
Did you ever get to the bottom of it?
Cheers sam
Post #757870 10th Feb 2019 10:29pm
kmac
Haven't had time to look into it = not used the car since the issues.
Will have a look when weather improves
Post #757872 10th Feb 2019 10:32pm
