![]() | Home > Puma (Tdci) > Park-ign-off key out engine still running!!! |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 835 ![]() ![]() ![]() |
2011MY 2.4 Puma 110XS USW
Went for a short run this morning, pulled up, switched off, removed the key and the engine kept running for 10 or so long seconds, then stopped. Anyway the rest of the journey involved 4 more stops. Stops 1,3 and 4 were normal,the engine stopped as soon as the ignition was turned off. Stop 2 the engine ran for around 5 seconds after ignition off. No faults are recorded. My concern is that a problem is developing. Any ideas? |
Could be nothing more than a sticky fuelpump relay...
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 751 ![]() ![]() ![]() |
I'm no expert but was told yesterday as my fan and radio sometimes don't turn off that the key barrel gets warn and dry causing the pins stick. I'm planning on squirting some good old WD40 down into it to see if it helps.
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1343 ![]() ![]() ![]() |
Latest JLR recall modification to make it even easier for lowlife to steal.
![]() Seriously though, I hope you can find the fault. |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 817 ![]() ![]() ![]() |
Hopefully, this will resolve your woes. If it doesn't however, your ignition switch may be on its way out. |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 373 ![]() |
I wouldn't use spray oil, dust and dirt stick to it and cause problems. Use graphite powder, best dry lubricant for locks instead. I also think it has to do with a broken lock or coil. |
Also check the rear stop lights
On mine with certains LED bulb I had the same issue. The engine still running w/o key in place. In this case when I pushed the brake the engine stopped Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Thanks both - lubricated ign with graphite, around 10 stops today and no problems.
Thinking back releasing the clutch stopped the engine in the first instance. The law of unexpected consequences (especially with Defender Puma electronics) kicks in here, I have led brake, rear and indicator lights so will try your suggestion if (when) it happens again. Thanks for your responses ![]() |
Phil VM2.5 Member Since: 28 Mar 2012 Location: Limelette Posts: 196 ![]() ![]() ![]() |
Hi,
I have sometimes the same. The engine stop when I turn off the ligts ... Or I have the etc light on when I put the light "on" Seems to be related with a not good earth but where ! It is sometimes so I did nothing , also because what to do ? Philippe current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
