![]() | Home > Technical > Blowing Reverse Lamp Fuse |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1343 ![]() ![]() ![]() |
As the LED bulb should draw minimal current, I would not replace with a bigger fuse.
The fuse is there for a reason ![]() My guess is there must be a problem with the wiring going to earth somewhere. A case of tracing it back and eliminating each section ![]() |
big110 Member Since: 02 Nov 2016 Location: Pinner Posts: 389 ![]() ![]() ![]() |
Me was afraid you were gonna say that mate!!! ughhhh
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20968 ![]() ![]() |
^^^^ Agree, certainly don't increase the fuse rating it's there for s reason to protect the circuit and wiring.
There will either be a switch failure, short in the live or a poor earth. My guess would be the switch, but do some testing with a Multimeter to determine there is suitable voltage at the plug and low resistance on the Earth line again at the plug. Is the plug and socket got wet in it at all? ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
[quote="big110"]I had the reverse lamp burned out, so I thought. Fitted a new fuse, worked fine. Have since swapped for an LED bulb which was great
