Home > Puma (Tdci) > Weepy wheel? |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
could be one of a few things really. take the wheel of and take a look.
13th Jun 2011 5:56pm |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 4990 |
You got a dog
13th Jun 2011 6:10pm |
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 |
Ha ha... if only, he'd chase away the neighbour's cat - who is fond of taking dumps in our flowers. |
13th Jun 2011 6:14pm |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
Could be anti seize that they put on between the hub and wheel. Is the backplate wet? Steve.
13th Jun 2011 6:51pm |
cinstone Member Since: 29 Nov 2010 Location: Stourbridge Posts: 375 |
Stick ya finger on it and smell it. That should narrow things down.
Chris. |
13th Jun 2011 7:56pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
It would be worth checking the brake fluid level as well. If it's not at the full level take off the wheel and check that the brake pipes not cracked/split. Also check the bleed nipple (if it has one, not checked) hasn't been sheared off or is loose. Also check the shock absorber isn't leaking oil. Once the wheel is off dirt will have adhered to the oil so you will be able too see where it is coming from.
13th Jun 2011 8:19pm |
I'll have 10 p on shock absorber.
13th Jun 2011 8:24pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5024 |
I bet the dealer will still say they all do it. Mike
13th Jun 2011 9:19pm |
yanto Member Since: 03 Sep 2009 Location: caerleon Posts: 230 |
would'nt brake fluid burn through the paint??
13th Jun 2011 10:04pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4510 |
Had a leaky break cylinder on a tdi do something similar but on the inside of the wheel. Then again they were drum breaks so I would check the brake fluid level as suggested. Also do you notice any difference in how the vehicle comes to a stop when you apply the breaks? 1982 88" 2.25 diesel
13th Jun 2011 11:15pm |
Thanks for the suggestions, I'll take the wheel off today or tomorrow and have a look!
14th Jun 2011 6:07am |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
my bet is, If it isn't the drive flange leaking then it's the inner bearing grease seal Original Member Pie n Pea Club.
110 HCPU Tipper |
14th Jun 2011 6:53am |
iruffell Member Since: 03 Sep 2010 Location: Marlow, Buckinghamshire Posts: 343 |
I had that on my old TD5, turned out to be a broken hub, the garage where surprised it hadn't seized up and exploded so I suggest you get it looked at ASAP
14th Jun 2011 11:07am |
