![]() | Home > Td5 > Clutch adjustment? |
| Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2378
Make one, requires the sacrifice of a spanner. Once made you have it forever or until you lose it 😉
| 4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 987
Clamp a pair of needle nose vise grip pliers (mole grip I think you guys call them) on the threaded shaft and use a wrench on nut.
Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
| lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3325
That’s an idea, thanks l will give it a try.
Also l have ordered two spanners to see if l can cut them down to fit. |
| Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5347
lighten check your master cylinder for leaks too, just in case. My dads had a problem. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Can anybody tell me if a TDCi clutch pedal box/master cylinder is the same as a TD5 one?
I can answer this as l have just fitted one.
Yes it will fit in place of a TD5 assembly, one mounting hole is in the wrong place but you can either leave it with five bolts or drill an extra hole. The clutch switch is different on the TDCi. Although it looks the same, it’s a normally open switch where the TD5 one is normally closed. So you also need to swap it with your TD5 switch, a very easy job which takes a couple of minutes. After 100,000 miles the pedal mechanism had some play in it so now the clutch action is better, with less play before anything happens. Plus the TDCi pedal has the assist spring already fitted and this makes for a lighter clutch action. |
I also figured out a way to get to the locknuts on the master cylinder rod without modifying spanners to fit.
Wedge the clutch pedal down. Loosen the nyloc nut on the end of the master cylinder rod until it’s as far off the end as possible without falling off. Release the clutch pedal. The clutch pedal arm will end up against the nyloc nut, leaving the two locknuts clear of the arm and accessible with ordinary spanners. |
OK so l have loosened the locknuts
Can someone tell me the correct resting position of the clutch pedal? The service manual says that the bottom of the pedal should be 140mm from the floor. But it doesn’t say whether that is with or without the pedal rubber fitted. |
With... to bottom edge of pedal.
Thank you.
