![]() | Home > Maintenance & Modifications > Light bar behind lower grille? |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
You need to speak to Porny on here AKA Ian Baughan on the book of faces. His is the neatest fit I’ve seen produced. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp Roy |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3742 ![]() ![]() ![]() |
Thanks Roy. Not on FB so I’ll have a look around here.
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4807 ![]() ![]() ![]() |
Didn’t Grafty do this as well?
![]() 2008 SVX 90 2000 XS TD5 90 |
LR Sam Member Since: 08 Nov 2012 Location: Yorkshire Posts: 236 ![]() ![]() |
grafty gave me the idea for mine! Mine is a non air con td5. The light isn't blocked that much but obviously isn't as good. Il get a photo tomorrow Col. I didn't want a light bar anywhere on the outside so was useful place to put it
Thanks LR Sam, thats exactly what I’m after.
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7929 ![]() ![]() ![]() |
There is a good thread showing this, just need to try and remember who's it was. It was one of my fav build threads but now sold on... give a while... James
Found it, page7 https://www.defender2.net/forum/topic39625-90.html James
Well found James
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Here's my setup. Non AC
![]() ![]() Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
legin Member Since: 22 Jul 2017 Location: Chelmsford Essex Posts: 1004 ![]() ![]() ![]() |
grafty99 Have you got a picture with the lights off ,can the LED's still be seen in day light ?
That should give you an idea, you can still see them, but it's not too obvious
Looks very smart George
Thanks Grafty, much appreciated. Which light bar did you use?
Thanks for the picture grafty. The LED bar hardly shows also they don't stick out like spot lights would and spoil the lines of the front end .
