Home > In Car Electronics > Help locating Flasher Relay for LED bulb upgrade |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 854 |
Top left as you look at it. I did mine a few weeks back. My original relay fell into bits when i removed it and mine is only 5 years old.
The 99 one nest to it is the programmable washer relay. Well worth it for a tenner for intermittent wipers. Check the forum for info. |
1st Feb 2019 3:05am |
big110 Member Since: 02 Nov 2016 Location: Sweeden Posts: 342 |
thanks for that. I did the wiper relay mod, been fantastic. So this is under the dash, not under the seat box correct
1st Feb 2019 3:06am |
Yep. Just next to it. Pop it out and pop the other one in.
I was told to change all the bulbs first to LED then turn them on as the relay might have an issue with the two different types of lights. Can't see why so tried mine after each bulb change. Worked fine. If one doesn't work the wiring is probably wrong on the vehicle side. LEDs are directional. The originals aren't so wiring may +ve -ve need to be swapped. |
1st Feb 2019 3:13am |
MC84 Member Since: 22 May 2016 Location: Near Bristol Posts: 341 |
My recent Wipak kit came with a coloured instruction page showing the relay that needed swapping. Although the clicking when indicating the old relay made also narrowed it down Mike
Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
1st Feb 2019 3:58am |
instructions were for TD5 mate, as were all the pictures...
5th Feb 2019 5:35pm |
Kent_keith Member Since: 01 Jun 2014 Location: Kent Posts: 388 |
I did this yesterday, massive improvement, I’d recommend getting a set that looks stock since they are so easy to remove, my flasher unit was behind the dash on an 05 2005 TD5 90 CSW XS
6th Mar 2019 8:13am |
benniferj Member Since: 20 Oct 2016 Location: Basingstoke Posts: 361 |
Turn on the indicators and listen for the ticking, follow it, touch the relay, youl feel it ticking.
They are in different places on different revisions of the car! |
6th Mar 2019 9:11am |
