Home > Series Land Rovers > Wolf wheels do they require longer studs
Stacey007
Hello
I quite like the look of wolf wheels (in limestone) and Chucky tyres for my series. Questions...
1) Do you have to fit longer studs for these to fit as priced these up as an additional £150
2) looking at a second hand set it says the come with inner tubes? Do they have to be fitted or can audinary tyres be fitted?
This type of wheel
This type
Post #756386 4th Feb 2019 10:54pm
1) Some say yes, most say no. LR themselves fitted Wolf rims with standards studs, so no is correct.
2) There are two variants of Wolf rim, one for tubes and one for tubeless. You cannot fit tubeless tyres to tube-type rims, but you can fir tube-type tyres with tubes on tubeless rims.
Post #756395 4th Feb 2019 11:06pm
Mountain_man
Wales
What he said. My mate is a fireman and the LR 130 tender straight from Land Rover Special Vehicles is fitted with Wold HD wheels. The top of the wheel stud is about 2-3 mm down INSIDE the wheel nut.
Post #756454 5th Feb 2019 9:29am
They will also work with long studs... so there's no correct answer.
For peace of mind, I fitted long studs.
If you're fitting them on a Series, I'm not entirely sure they'll be as long as a Defender stud with the 'line' across the end? QRZ 2e0vpf
Post #756459 5th Feb 2019 9:57am
JOW240725
I tried fitting Wolf to my 1984 Ninety and wasn't comfortable that the stud was only about 3/4 through the nut. I'm sure it would be fine but for for the sake of £150, I personally didn't want to risk it. They do now protrude a long way though.
 James
Instagram @suffolk_rovers
Post #756462 5th Feb 2019 10:19am
Mdm
the army have old and new lr with wolf wheels fitted without issue and they have a fair few and use them hard sometimes.
eg 3.6 and 3,8 ton 110 and 130 and thats before they overload them with folk and their kit.
there are tech bulletins from lr on the subject if you ask them about it im sure they will share the info with you.
Post #756534 5th Feb 2019 5:40pm
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
Britannica Restorations mentions in that the British Army used standard studs but applied higher torque to the bolts: 170Nm.
Regards,
Joris Antares Treadwell, a MY06 110 Td5 in Chawton White
Post #756547 5th Feb 2019 6:28pm
The nuts should be tighter for the Wolf steel wheels, that is correct.
The question of stud length and nut torque has discussed many times before on this forum.
Post #756570 5th Feb 2019 7:55pm
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
I have Wolf wheels on my Series One. I also have the old style reversible wheel nuts, which are longer than the normal nuts, and so I have fitted longer studs, as it would look really odd otherwise. I guess it would have been cheaper to fit later style nuts, but I like the security of the long studs. Euro-Leafing to infinity and beyond.....
Post #756577 5th Feb 2019 8:09pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
I should have a spare set of “wolf” studs in the workshop if you decide to go that route, sure we can make it cheaper than £150 Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #756616 5th Feb 2019 10:10pm
