![]() | Home > Technical > DPF in 2.2 tdci engine |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Diesel Particulate Filter
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
i wonder what happens to a DPF if you add a drop of 2 stroke to you fill ups BM52
if it is a good 2stroke synthetic oil........ nothing!!!! oil reduce particulate emissions....... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813 ![]() ![]() |
Was just wondering that myself and had been thinking along the lines of dgardel. I suppose if you had a couple of steep hills in your area that would be beneficial too. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 764 ![]() ![]() ![]() |
I thought that I read somewhere on this forum - 2 stroke oil thread - that you should use FB 2 stroke oil because the Puma had Cat and synthetic particules don't burn well and clog the cat ?... or is it the other way? you should use FC (synth oil) because it has Cat ? ![]() Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
FC spec for the Puma. 1982 88" 2.25 diesel
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
Considering the TDv6 has to have oil that supports the DPF - i wouldnt jump to conclusions that adding 2 stroke is ok Mike
