Home > Off Topic > Disco 300tdi auto is it fly by wire or not?....
v8bobber
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Java Black
Hi all,
I’ve bought a 300tdi auto (well it was free) so I can use the engine and gearbox in another machine. I’ve read that some are fly by wire. How can you tell? This is a picture I took of the tip of the pump
Post #755720 2nd Feb 2019 6:43pm
donmacn
well, that all looks pretty mechanical to me, but on the other hand, it doesn't look much like my 300tdi. Too dark and cold to take a pic just now, but i can do it tomorrow if no-one else has chipped in.
What I'm not seeing is the vacuum advance for the fuel pin/diaphragm.
If you were to look at one of the online parts diagrams, that should help you pin it down? Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #755738 2nd Feb 2019 7:38pm
v8bobber
This was the other side and looked a lot more complicated than normal....
Post #755739 2nd Feb 2019 7:45pm
donmacn
Yup! None of that gubbins in my Defender. Presume thats the EGR and air filter stuff? Donald
in the past..
Post #755747 2nd Feb 2019 8:14pm
donmacn
Just found this online - referred to as a 300tdi auto electronic pump, so that does look more like what you have?
 Donald
in the past..
Post #755748 2nd Feb 2019 8:18pm
v8bobber
My own fault that I didn’t have a proper look at it. I remember reading that there was no mechanical linkage to the pedal but there clearly is on this one. I’m wondering now if they’ve put one in for the egr system.
Making an EDC system work in a comp safari racer doesn’t seem like my idea of fun at all!
Post #755766 2nd Feb 2019 9:09pm
donmacn
Sorry - I know nothing about EGR stuff - my car was one of the very first Defnder 300s and didn't have one.
With a forum name like V8bobber I'm guessing you don't have another mechanical fuel pump to swap over?
Shame you're so far away, I'd offer to take it off your hands! My garage man is suggesting it would be a good idea to get a 'spare' 300tdi and keep it in the corner of garage... Donald
in the past..
Post #755771 2nd Feb 2019 9:29pm
LiftedDisco
As above, the Auto can come with the electronic fuel pump which is the element that is generally regarded as ‘fly by wire’ but the throttle etc is all mechanical
Hope this helps...
Post #755775 2nd Feb 2019 9:46pm
The EDC on the 300tdi allowed LR to tune it slightly, so they're quite spritely compared to the manual. Darren
Post #755776 2nd Feb 2019 9:52pm
donmacn
...which is a 'good thing' ... as it just underlines that the engine basics will take the extra tuning/tweaking. Hopefully to a sensible degree, this is where I'll be going in the next 3 or 5 months. Donald
in the past..
Post #755821 3rd Feb 2019 12:30am
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
My 300 auto was ‘fly by wire’. The accelerator wasn’t mechanical, it was a potentiometer that would cost a fortune if it went wrong. Mines did start acting up, but thankfully I traced it to a dirty multi-connector in the engine bay, a good clean out with wd40 had it behaving itself again. Wasn’t a bad car, but very thirsty.
Post #755823 3rd Feb 2019 12:36am
Mountain_man
Wales
Possibly cruise control, and a mechanical pump. Mind you the later 300 mechanical pumps had some electronic gubbins associated with the EGR which makes them more difficult to tweak. But that is not a fly by wire set up in the proper sense of the word.
Post #755885 3rd Feb 2019 12:12pm
