Home > Maintenance & Modifications > Silent coat wheelarches / tub
Oldowner
I am going to silentcoat my rear tub wheelarches on my 90 hardtop at some point with the 2mm sheets. If I apply it internally as I’ve seen done quite a few time on the forum, does the original Land Rover one piece rubber mat still sit okay over the silent coat?
I have thought about applying it externally on the underside of the wheelarches instead. Anyone see any problems with that? Does it withstand an external application? Obviously I’ll have to cut it to fit around the reinforcing sections.
Thanks
Post #755177 31st Jan 2019 8:41am
jst
External? Really? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #755180 31st Jan 2019 8:57am
PCM
I used the 3mm black silent coat all over mine, then applied think exmore carpets and the mat still fits. (looks V cool)
Had to trim carpet around the doors a bit, but no issues with the mat.
Post #755183 31st Jan 2019 9:08am
It's really not designed to be applied externally. It's quite a soft material and I can imagine it being slowly shredded under a wheel arch. Darren
Post #755184 31st Jan 2019 9:08am
