Home > Puma (Tdci) > Defender 2.2 l MY 13 Fire in the Cabin
CaptainDan
Australia 2013 Defender 130 Puma 2.2 HCPU Alaska White
Hi All
I just wanted to share a very worrying story which happened yesterday while driving my MY2013 Defender 130. I smelt burning in the cabin followed very shortly by thick black smoke which filled the cabin after turning off the ignition and bailing out and looking underneath the vehicle with nothing to see I returned to the drivers seat and saw flames coming from the handbrake boot. I dumped some water which was all I had and put out the flames which were not big but getting bigger. When the smoke cleared I removed the handbrake boot to find the electrical lead to the handbrake switch had burn through the insulation and arched onto the handbrake. i would have though it would have blown a fuse or something but the wire was completely burnt through to the core and shorting out. It must have generated a lot of heat because not only was the insulation burn as well as the floor matting ant the boot but it seemed to have melted the handbrake cable because when i applied the handbrake the cable seemed initially soft and then broke completely showing signs of heat damage.
I just wanted to alert others to this potential problem and recommend you remove the boot and take a close look at the condition of the wire to the handbrake switch before you have a similar situation as I had which could have been so much worse. If anyone else has had similar problems please let me know and share this around.
Daniel
Post #754742 29th Jan 2019 12:47pm
ickle
I would guess you've ' lost ' the main chassis / transmission earth strap and the drivetrain is earthing through the handbrake cable - the little cable to the handbrake if shorted to earth would only illuminate the hand brake on light, it only goes to earth through the switch anyway, so its collateral damage only.
Have you had any mechanical work done recently that would have removed the earth strap or it may have vibrated loose on your roads.
Have fun!
Keith
Post #754749 29th Jan 2019 1:17pm
JOW240725
Sounds scary! Hope you get it fixed without too much bother. Be interesting to hear what the casuse was. James
Instagram @suffolk_rovers
Post #754797 29th Jan 2019 4:27pm
CaptainDan
Hi Ickle
Yes I just had a new engine put in the vehicle 2k Kms ago now I am worried where do I find the main chassis earth strap to check if it has come off?
Thanks
Daniel
Post #754826 29th Jan 2019 7:34pm
Caterham
flaming heck, could have been much worse.
here's a picture of what I believe to be the main earth on the transfer box.
sorry only photo I could find. if you look carefully - middle of photo to the rear. the black earth cable. mine was rubbing on the transerbox /gearbox to chassis mount (the rubber mount has a metal heat shield which it was rubbing on).
sorry not the best but hope it helps?
Post #754829 29th Jan 2019 7:43pm
CaptainDan
Hi Caterham
Ok thanks it could have been worse I cannot see your photo though do you think it is ok to drive?
Post #754831 29th Jan 2019 7:52pm
CaptainDan
I can see the photo now thanks
Post #754832 29th Jan 2019 7:53pm
Caterham
I had various indicator issues when mine wasn't tightened, and from what's already happened (assuming that is due to a missing earth(?))
I say get the earth sorted before using it - even if it's only a temporary one.
the other thing I'd be inclined to do is check that you've got the right size fuse in place for the hand brake.
Post #754833 29th Jan 2019 7:56pm
LR90XS2011
Have fun!
Keith
As Kieth says this has all the symptom's of an earth fault not a hand brake light fault, take it back to the people who changed the engine it is an issue they have probably caused but dont drive it until sorted. DEFENDER 90 TDCI XS,
Post #754840 29th Jan 2019 8:50pm
ickle
I always put an extra earth strap on anyway, chassis to engine, chassis to battery box, chassis to bulkhead, they can't hurt and may well help.
And as above - don't drive it! The inner and outer parts of the handbrake may be welded together - replace it anyway.
Good luck
Keith
Post #754882 29th Jan 2019 10:53pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I had a attempted theft where they cut the earths, I'm guessing to deactivate the alarm. A lot of my wiring runs through the cab so they were not successful but it melted my handbrake 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #754886 29th Jan 2019 11:16pm
CaptainDan
Thanks everyone for your comments and advice I am taking it to the auto electrician for them to take and look and will get those extra earth straps fitted
Daniel
Post #754909 30th Jan 2019 7:48am
CaptainDan
Just a final update I took my Defender to the auto electrician today and confirmed that the earthing is ok, and I also took out the old handbrake cable. The insulation is completely melted along the full length to the drum so the little wire which was arching onto the cable core must have generated a lot of heat. Will replace the cable tomorrow and blank of the wire to the handbrake switch, so no more light on the dashboard but a small price to pay given the damage cause and how much worse it could have been.
Daniel
Post #755218 31st Jan 2019 11:43am
There is absolutely no way that a fault with the wiring to the handbrake warning light switch caused your handbrake cable to get that hot. Whatever the autoelectrician may say, the only way that this could happen is if the earthing between the engine/gearbox and the chassis has failed.
It would require a very considerable current to be flowing through the core of the handbrake cable to make it that hot, and it is exactly what happens when an earth fault causes the earth path for the alternator to divert through it (100+ Amps, unfused).
Your autoelectrician is either mistaken or is pulling the wool over your eyes.
Post #755230 31st Jan 2019 12:14pm
Retroanaconda
Indeed. Earthing through the handbrake cable is a known Defender fault.
The little handbrake light cable has nothing to do with your issue.
Post #755313 31st Jan 2019 8:38pm
