Home > Technical > Arb pressure switch |
ibexman Member Since: 13 Dec 2008 Location: kent Posts: 2872 |
£6.36 from flatdog. Turn on 70 off at 100👍 Cheers Chris
27th Jan 2019 2:26pm |
Steve_overland Member Since: 14 Oct 2018 Location: Gaydon Posts: 282 |
Will order one right now cheers @steve_overland on Insta.
110 expedition vehicle with pop roof |
27th Jan 2019 2:35pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7686 |
It's 1/8npt, Ashcroft lockers run better at slightly higher pressure in my experience. I run a 90/120. Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
27th Jan 2019 10:05pm |
https://www.ebay.co.uk/i/292063641260?chn=...7efff34eee Cheers
27th Jan 2019 10:07pm |
Put a pcl female on the 1/4 fitting too for air tools. Use an old air suspension cylinder as res. All road ones around £30 on the bay. Cheers
27th Jan 2019 10:10pm |
The even cheaper way to get an air tank is the disposable welding gas bottles. They have a 1/8th BSP connection on them. I have a 1/4" braided hose going from the compressor to the tank, then I've tapped a 1/4 BSP hole in the other end.
The ARB compressor uses 1/4 NPT fittings but they're near enough to 1/4 BSP that they're interchangeable at that size. |
29th Jan 2019 12:24pm |
