Home > Tdi > LT77 tunnel clearance with R380
Defendermatt
United Kingdom 1989 Defender 90 Other SW Bonatti Grey
Can anyone help confirm if the tunnel from a 200tdi will fit over a 300tdi R380?
I plan to mount the R380 on the LT77 mounts so I can keep the original seatbox, but will the bulkhead tunnel clear the 300tdi bell housing??
Post #754446 28th Jan 2019 10:28am
ibexman
You may have to use a bulkhead diaphragm
Post #754455 28th Jan 2019 11:16am
oneten110
Given that the LT77 and R380 are basically the same gearbox there shouldn't be any problems It is not a Defender, it is a One_Ten
Post #754541 28th Jan 2019 6:55pm
Defendermatt
The bell housing of the 300 tdi r380 is considerably larger than that of the lt77. Is this why the tunnel size was increased?
Post #754683 29th Jan 2019 2:27am
oneten110
Whilst the gearbox remained in the same location, when the 300 was introduced the engine was moved forward 8 inches, hence the longer bell housing. Plus the R380 has a longer input shaft.
There is a short bell housing available for the R380 to enable its fitment with alternative diesel engines, presumably with a shorter input shaft It is not a Defender, it is a One_Ten
Post #754711 29th Jan 2019 9:50am
