![]() | Home > Maintenance & Modifications > Seat riser rails comparison -- too much choice |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
Horses for courses i suppose ......i personally just wanted to be abe to move the seat backwards a little further with minimal seat rise (depends on body shape rather than overall height i suppose) These mulgo seat raisers are ideal for this https://www.roamingtheoutback.com/2013/12/...xtensions/ but you cannot get the mulgo product in europe! Overlander do sell a very similar product and with your caveats noted they do what i want from them . https://www.4x4overlander.com/product/defender-seat-rails/ |
which ones did you use? 1 https://www.4x4overlander.com/product/defender-seat-risers/ 2 https://www.4x4overlander.com/product/defe...s-premium/ 3 https://www.4x4overlander.com/product/defender-seat-rails/ 3 gives you the best angle for my bodyshape! |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 ![]() ![]() ![]() |
They didn't work for me - they lasted on the car one week before I removed them.
At 6,2", my eye line is inline with the top of the door window. Raising the seat up by even just the 20mm or so needed to clear the back of the seat box means that I could no longer see out the side window without tilting the neck down - gave me right neck ache. I would echo what has been said above - try it with washers before you buy a set, just to see if you can live with the raised seating position. 2005 Td5 90 XS 1989 V8 110 CSW |
I went with the washers to try it out, and then never ended up needing to buy anything else.
drakes Member Since: 09 Oct 2009 Location: Consett Posts: 115 ![]() ![]() ![]() |
same here, just used a few nuts that I had in the shed
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 370 ![]() ![]() ![]() |
Like a few others I tried commercial seat risers on my old Td5 and on the current Puma but all of them raised the seat too high to see out of the side window easily. So I reverted to a few washers and then a mate at work offered to turn me up a few spacers since I'd run out of the standard thick washers.
This is my arrangement - see how close the sliding part of the seat is to the lip - the absolute minimum necessary. That works for me at 6'3". ![]() Click image to enlarge Dave Green Goddess - 1998 Defender 110 300tdi |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 403 ![]() ![]() ![]() |
Great idea! I also find looking out the side window somewhat difficult ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4283 ![]() ![]() ![]() |
I might be missing something here, but the point of the commercially available riser is to move the seat runner up and backwards isn’t it? Up to get the runner higher than the lip on the back of the seat box, and then backwards to give the extra legroom. How does adding just washer allow the seat to go further back? 2007 110 TDCi Station Wagon XS
The seat will slide further back than the lip on the seat box allows. Lifting it over the lip gives you about 2 inches of extra legroom. Dave
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5939 ![]() ![]() |
It will give you a little bit more leg room, but you will gain more from rails that move the fixing points further backwards
