Home > Technical > Am I missing a transmission mount?
Roverdude
United Arab Emirates 2014 Defender 90 Puma 2.2 SW Tamar Blue
Just purchased a 2014 D90 SW Puma. While doing first oil change on it, I noticed that the top of the cross member below the transmission has a bracket that ends an inch or two below the transmission. On the transmission there's a small threaded hole. It looks like a mount of some sort would go here, but I really have no idea. Can someone help confirm whether this is normal or I'm missing a part?
Post #754244 27th Jan 2019 10:33am
No, they're all like that. Darren
Post #754246 27th Jan 2019 10:39am
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
It's the audible warning device. If the powertrain comes loose then it goes donk donk donk every time you go over a bump, to alert you of the issue. Or you can fit a whoopee cushion Mr. Green ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #754293 27th Jan 2019 2:07pm
Rashers
Rolling with laughter Rolling with laughter Rolling with laughter
Post #754326 27th Jan 2019 4:40pm
I'd be more concerned that the vehicle is upside-down.
Post #754347 27th Jan 2019 6:37pm
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
I’m sure there must be a market for making a nut and bolt to suit that and sell it as a replacement for the missing item šŸ˜‚
Post #754350 27th Jan 2019 6:56pm
