Home > Td5 > Viscous fan removal
excossack
Viscous fan removal
To remove the viscous fan, am I correct in thinking that as you look at the fan from the front, its a left hand thread?
I have the two spanners required. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #754002 26th Jan 2019 10:25am
DefenderJon
Northern Ireland 2000 Defender 90 Td5 CSW Epsom Green
It’s a right hand thread. Anti-clockwise for removal.
Jon. Defender 90 TD5 CSW - The longer I own it, the newer it gets!!
Post #754003 26th Jan 2019 10:28am
donmacn
I bought a spanner off the web - what I'd have thought would have been a decent thing, and it was carp. The fan may not have been off in a while, so it was tight, but not excessively I wouldn't have said. The jaws just opened up and deformed.
I ended up taking a grinder to a 32mm spanner I had, to thin it down enough. Worked perfectly.
This was in a Tdi, and I've never had to do anything on a TD5, so it might be different.
Just food for thought in case it doesn't go as easily as you'd like. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #754006 26th Jan 2019 10:43am
excossack
Cheers for the info chaps. 1999 Defender TD5 110
Regards
John M0VAZ
Post #754013 26th Jan 2019 11:20am
roel
I made my own special tool and use a hammer to kick it loose. Roel
2003 90 Td5 (2009-now)
Post #754397 27th Jan 2019 10:03pm
Glad you got sorted John, sounds like you're doing some work on her!!
Here's the spanners to go for, mine have the td5 and v8 logo stamped in them though.
 QRZ 2e0vpf
Post #754403 27th Jan 2019 10:17pm
excossack
Not done any work yet. Ordered a new fan unit and service kit today.
Some jobs i have been putting off plus down time from motorsport events plus 2 weeks off gives me some time. 1999 Defender TD5 110
Regards
John M0VAZ
Post #754408 27th Jan 2019 10:27pm
Don't forget the plastic bag for when you're removing the main oil filter Thumbs Up QRZ 2e0vpf
Post #754411 27th Jan 2019 10:34pm
Procta
Thanks greeni for that tip!! I always made that mess with the oil filters! I had to kebab defender and rover ones off, due to access. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #754415 27th Jan 2019 11:01pm
excossack
Good tip Greeni. 1999 Defender TD5 110
Regards
John M0VAZ
Post #754868 29th Jan 2019 9:56pm
excossack
Viscous fan off - with the help of a copper hammer. The fan spanner wouldn't budge, so a quick knock with a hammer gave enough to move the spanner.
All in all not a bad job with the right tools.
Philips screw driver for the fan shroud
Set of fan spanners (Flatdog in this case) others makes I am sure are available
Hammer to shift the spanner enough to get it started
A replacement fan
and coffee. 1999 Defender TD5 110
Regards
John M0VAZ
Post #755008 30th Jan 2019 5:15pm
