Home > Technical > Defender TD5 Burning smell when Heated front screen is on?
Retrostu
United Kingdom 2005 Defender 90 Td5 XS CSW Java Black
Sorry to be a pain but can somebody please help me out, every time I use the factory fitted heated front windscreen on my 2005 defender TD5 XS I get a burning smell similar to hot plastic but with no smoke.
I think it is coming from behind the clocks where the indicator relay is located? is that where the HFW relay is located too?. could this be the problem?.
The screen itself works well and does exactly as it should, I’ts just the smell is a little bit on unnerving. It's more important to concentrate on what's ahead of you than what you have left behind.
This is what I keep watching to remind me why I own/keep my Defender. https://youtu.be/x4DZgOcgn1s
Post #753491 23rd Jan 2019 10:41pm
dorsetsmith
may be wiring getting hot for heated screen, one side heated screen wiring run up to the screen behind the dash binnacle
see below
Post #753504 23rd Jan 2019 11:14pm
Retrostu
Nice one Dorsetsmith thanks.
I’ll check it out tomorrow, so basically it’s the yellow far left in centre console fuse box. It's more important to concentrate on what's ahead of you than what you have left behind.
Post #753509 23rd Jan 2019 11:30pm
dorsetsmith
Also heated front screen timer too only has light control load behind the dash binnacle RH side next too direction indicator relay
Post #753512 23rd Jan 2019 11:37pm
Retrostu
Also this would explain the smell too?. It's more important to concentrate on what's ahead of you than what you have left behind.
Post #753517 24th Jan 2019 12:23am
