![]() | Home > Puma (Tdci) > Station wagon 07 Puma 2.4 idling problem...help please! |
| GeorgeTDI07 Member Since: 14 Jan 2019 Location: Suffolk Posts: 5
Thanks for all the comments we're going to change the VCV again before looking at the high pressure pump - we haven't been able to complete a 'pump learn procedure so the problem does seem to be in teat area.....
Also going to replace the clutch switch...!
| williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441
They'll run ok without a pump relearn, so fit another vcv a give it a go
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21044
There is a lot of confusion (deliberately?) with sellers of VCV’s if they are brand new or recon. Never a clear answer hardly but a distinct significant price difference is rather telling. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
| hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 373 |
Buy the valve only original from Denso (part number DCRS300260). With *bay (usually from UK) forgeries are sold at the half price. Ford prescribes the exchange together with the PRV (pressure relief valve). Would follow that recommendation...
| ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282
Are you sure you haven't got air getting into the fuel lines?
Could be a dodgy fuel filter, loose injector pipes? I had a cheap fuel filter once that restricted fuel flow. It would start fine but once it emptied the can it would cut out. Just a thought Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
| Tomotomo Member Since: 13 Feb 2018 Location: Bucks Posts: 71
Hi Did you get this sorted in the end?
| All times are GMT |
