![]() | Home > Maintenance & Modifications > Fitting the Terrafirma Extreme 12 inch travel mega sport kit |
Nigelpugh7 Member Since: 18 May 2018 Location: Solihull Posts: 115 ![]() ![]() |
As always with what seems like a simple job, it was time to get the air tools on the top shock mount.
As usual, despite lots of WD40 the top shock bolt was not for coming off. So in the end we decided to just row the whole shock tower off. ![]() Click image to enlarge ![]() Click image to enlarge |
So we had been told our car had a two inch lift, but it now seems it was not the case.
On pulling the D44 shock tower and shock itself off, together with the spring we now realised it was only about a 1 inch lift with a spacer. ![]() Click image to enlarge ![]() Click image to enlarge |
Next job was getting the shock tower in place.
It took some cutting and bending of the inner wing to get it in place. ![]() Click image to enlarge But after a bit of cutting and bending it went in quite easily. |
Next job was to get the spring and dislocation cone in place.
A bigger challenge than you realise, as the +2 inch springs need the axle to be almost of the floor and the chassis as high as it can get. ![]() Click image to enlarge ![]() Click image to enlarge |
Next part, the big one, getting the shock in position.
If you’ve never seen one of these shocks before, it’s hard to believe just how big they are! ![]() Click image to enlarge ![]() Click image to enlarge |
Now the next challenge, getting the huge shock in the right position.
The issue of course, is one, where to put the remote reservoir, and two where to angle the output of the hydraulic pipe to feed in the right location, without fouling all th rest of the stuff in the local area! ![]() Click image to enlarge ![]() Click image to enlarge |
So top down, or bottoms up to get the shock in.,
We went for top down. ![]() Click image to enlarge ![]() Click image to enlarge |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11043 ![]() ![]() |
Good phone pic's
![]() Good progress there, once you have done the first one, the others should be a bit easier to do ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
On to the semi final part.
Offering the whole assembly into position. ![]() Click image to enlarge ![]() Click image to enlarge |
As you can see we chose to put the remote reservoir inside the outside part of the wing.
Only reason for this was space under the bonnet was limited. And we did it like this last time. Any other suggestions before we finally fix it in place? ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Now it’s all in place we know it’s much higher than the previous installl.
These pictures might not show it, but the whole car, once settled back on it’s whewls and jacks and stands off is 3.5 inches higher on the off side than the near side. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Cheers Clayton! Yep,we hope so! We had put it off for months, but in reality even with the seiezed bolts the whole off side took less than 2 hours from start to Finish! |
Finally finished off the rest of the front suspension
Mounted the hydraulic bumpstop and the remote reservoir too. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
A member contacted me to say that he wanted to know about the rear suspension install..
Sorry but for some reason I only update the other thread with the rest of the photos. Here’s the rest now. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
