Home > Tdi > Why has my MPG dropped so much? |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4784 |
Has the injection pump timing been checked? 2002 90 Td5 Station Wagon
17th Jan 2019 6:21pm |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 296 |
Might just be the winter diesel that’s in the pumps November to March.
I get a small MPG drop each winter. |
17th Jan 2019 6:53pm |
yostumpy Member Since: 01 Aug 2010 Location: n/kent Posts: 327 |
https://www.pistonheads.com/gassing/topic....;t=1632376 'Volvo XC 70, taking the rough with the smooth’
17th Jan 2019 7:19pm |
richcl Member Since: 25 Mar 2011 Location: tewkesbury Posts: 25 |
Agree with above, winter diesel.
Would rather loose a bit of economy than have fuel waxing. |
17th Jan 2019 7:23pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2545 |
Check your tyre pressures too.
17th Jan 2019 7:31pm |
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3335 |
Well, every day is a School day! Had no idea there was any difference, but it makes sense. I have never checked the Defender's MPG. |
17th Jan 2019 8:00pm |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 512 |
Just trying to think outside of the box, but, This doesn’t coincide with your change in air filter system by any chance ?
17th Jan 2019 11:39pm |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 572 |
Possible an air leak somewhere between turbo and engine, loosing a bit of pressure made by turbo. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
18th Jan 2019 10:00am |
foxhound Member Since: 02 Mar 2013 Location: United Kingdom Posts: 357 |
thanks I'll check 110 Defender 300tdi & Penman trailer with ally exped top and roof tent |
18th Jan 2019 10:35am |
it started when the weather was still warm - shirt sleeves in Oct/Nov where i am so i don't think that is the cause. but i'll keep in mind, thanks. 110 Defender 300tdi & Penman trailer with ally exped top and roof tent |
18th Jan 2019 10:37am |
checked weekly, religiously. so that's not it thanks. 110 Defender 300tdi & Penman trailer with ally exped top and roof tent |
18th Jan 2019 10:38am |
improving the air flow to the donaldson filter with a 3 inch tube all the way increased the mpg from 27-28 to 29 (and 30.5 on a long run) I have experimented with a forward facing air ram head and my donaldson topspin head on top of the RAI tube but surprisingly that made no difference at all. 110 Defender 300tdi & Penman trailer with ally exped top and roof tent |
18th Jan 2019 10:41am |
Winter diesel has a big impact on my Tdi. You can see the cyclical seasonal trend of MPG over a two-year period quite clearly here:
Click image to enlarge |
18th Jan 2019 10:44am |
thanks for this and thanks for the pistonheads winter fuel link yostumpy. So far the injection pump timing and turbo air leak seem to be favourites - although having read up a bit on winter diesel it may be that it's not the actual temperature where I am that's the issue (and I use a rad muff to warm the engine), but the diesel mix the fuel companies sell. I'll ask my garage as it's the only place I full up at - their pump is accurate, I tested it and tested some big brands nearby and they were charging for more fuel than actually delivered! 110 Defender 300tdi & Penman trailer with ally exped top and roof tent |
18th Jan 2019 10:47am |
