Home > Tdi > Rear light setup on 300tdi
Page 2 of 2 <12
Martin
Site Admin
I know that’s what is on the diagram (I spent ages editing it all out to make the diagram I posted) but in real life the switch doesn’t make use of logic to connect the circuits.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #751830 17th Jan 2019 9:08am
dorsetsmith
LR past and copy Whistle Rolling with laughter
Post #751849 17th Jan 2019 10:55am
jimmythomson
I had a chance to play around with the indicators wiring today and though I'd share some info (though the solution is already well known).
The problem I was having with the indicators was that when I indicated either left or right, both sets of indicators flashed. So I indicate right, all indicators illuminate. Indicate left, all indicators illuminate. The LED lights that I'd fitted came from Bolt On Bits, and I'd seen info suggesting that their 'RDX Earth Fix Kit' would do the trick: https://www.ebay.co.uk/itm/RDX-Earth-Fix-K...2280619868
I wasn't happy with parting with money without knowing why i needed it, so I removed the instrument panel and took a look at the lights there...
The circuit diagram I've been looking at is for a 97 MY Defender, though I thought that it was supposed to be the same as my 96 MY. It turns out it isn't, as my dash only has one tell tale indicator light, whereas the 97 MY diagram shows one for left and another for the right.
The joint that I've highlighted in red below, doesn't exist on my dash:
Instead, I have a single indicator tell tale on the dash, and it's wired to be in the middle of the circuit joining the left and right indicators. Here's the accurate representation that I've created:
So let's say I indicate left. Current will flow through the indicator stalk, then it splits off so that one part of the circuit goes off to the left indicators, and the other part goes off to the dash tell tale buib. All the indicator lights are earthed nicely and so the left hand indicators flash as expected. Unfortunately however, as the dash tell tale has no dedicated and deliberate path to earth, the current has no choice but to head through the tell tale bulb and around and on to the right hand indicators, through the lights and back to earth. So I now understand why the Bolt On Bits earth fix kit will work.
Why wasn't this a problem with old non-LED bulbs? In the example above, in order for current to flow through the right hand indicators, it has to have gone through the tell tale bulb. This bulb effectively acts as a resistor, limiting the current to around 0.09A. The old non-LED bulbs needed a lot more than to turn on, and so remained off (I can't remember the exact figure, but I think it was 1.5A). The RDX LED bulbs however, only need about 0.08A to light up!
I've seen that people have wired in diodes in order to prevent current flowing to the opposite side of the indicator circuit, but from what I can see, this would just result in the tell tale bulb not working at all for me.
The solution does indeed appear to be the earth kit from Bolt On Bits. Seems like a lot of money, but at least it'll be a nice bright LED dash bulb.
Cheers,
Jimmy.
Post #751950 17th Jan 2019 8:44pm
dorsetsmith
fidy job getting all in side that small holder
not so fidy job
Post #752027 17th Jan 2019 11:42pm
Page 2 of 2 <12
