Home > Puma (Tdci) > Removing tank pick up
Tomotomo
Hi I am struggling to get my 2.4 130 to start and if I do get it start it idles really rough and if you touch the throttle it cuts out. Big Cry It has been laid up for 9 months, so I suspect the tank pick up may be blocked with deisel bug? Luckily I have no body over the tank so I can access it quite well. But what's the recommended way? Remove whole tank and slosh it out as best I can. Or remove pick up unit from tank ? Although how would it seal back up? Is it likely to get damaged ?
Many thanks
Tom
Post #751572 15th Jan 2019 11:22pm
HardCharger
If you want to remove the tank pick up, there is a special tool that you will need. Also, best to buy the gaskets between the pick up and the tank, just to be sure as it's a pain in the @$$ to do.
Are you sure that there is no leak in your system? Is the fuel filter loose?
If it is the diesel bug, you'll have to slosh it around and pour out the contents as the tank has no other drain options that I know of. Check your tank breathers while you're at it.
I hope this helps.
Post #751592 16th Jan 2019 3:50am
Tomotomo
Thanks that has helped a lot. I definitely want to avoid removing the pick up from the tank in that case. I am not sure it's blocked it's just behaving like it's being starved of fuel. If I remove the fuel lines from the tank I could try and draw some up another clear hose with a vacum gun . But I am nervous that I will loose all the fuel out of the lines and have to bleed everything which I have read on here can be a nightmare? Anyone know of a quick way of ruling out the pickup being blocked?
Post #751603 16th Jan 2019 8:10am
dorsetsmith
run your engine from remote fuel can and see how it behaves Idea
Post #751605 16th Jan 2019 8:19am
Tomotomo
Excellent idea.
I guess I can separate the flow at the filter and run my own line from there.
I will report back Bow down
Post #751612 16th Jan 2019 9:07am
dorsetsmith
Thumbs Up
i think filter head cormetors are 9.89mm
Post #751627 16th Jan 2019 9:58am
HardCharger
I guess you can check the pick up and return lines with your vacuum gun or some other method, if they draw and return with no issues then your pick up should still be good and you should search for a possible problem downstream.
Post #751832 17th Jan 2019 9:10am
Tomotomo
Thanks for all the help. I don't think I have a blocked pick up Cool .I eventually got it to start after a while. I then tried to look at some live data using forscan. I am not familiar with live diagnostics so I wanted to check that the fuel rail pressure of 1.33 volts is correct for idle and what a pilot correction status of 128 means. Any ideas
Tom
Post #752529 20th Jan 2019 12:12am
dorsetsmith
pilot correction status to do with fuel injector pilot learn
https://bellautoservices.co.uk/diagnostic-services/
2.4 work shop manual below
https://1drv.ms/b/s!AtZSoWFHDgnGhQoLf-ZCjkI5M0R7
Post #752556 20th Jan 2019 10:51am
Tomotomo
Thank you! Thumbs Up
Post #752571 20th Jan 2019 11:47am
