![]() | Home > Tdi > oil light |
| tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1125
on start up the oil light stays on for a few seconds from cold , ok when hot , anyone got a idea why ?
| Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 537 |
Cheap oil filter with no non return valve ? Wrong grade oil - too thin ? Goosed oil pump ?
many thanks , sounds like the pump then out of the 3 .
| white110 Member Since: 09 Dec 2017 Location: wales Posts: 10
low or lowish oil level
| yostumpy Member Since: 01 Aug 2010 Location: n/kent Posts: 327 |
Replace the sender unit, cheap as chips, bet it cures it! 'Volvo XC 70, taking the rough with the smooth’
never thought about the sender , anyone got a part number .
| Ellisboy Member Since: 13 Oct 2013 Location: Deep South Posts: 539
Sounds like it could be the sender,probably the cheapest part to change first!
Stephen. |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
anyone got a part number \/
for TD5 https://www.lrworkshop.com/diagrams/land-r...r_53224#18 and PRC6387 for TDI 200 / TDI 300 Last edited by dorsetsmith on 15th Jan 2019 9:45am. Edited 1 time in total |
| BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 403
Not sure about the Puma motor but on a 300Tdi, the oil light being on is to indicate that the sender is f*ed, about 999 times out of 1000. I have replaced at least a dozen senders on various vehicles I have owned, they went through a particularly bad patch in the early 2000s where every time the sender got wet, it would let water in and kept the light on, I think I probably had 4 or 5 in the space of a year. Definitely worth changing before looking any further. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
Thanks Gents, I order one today.
Yes it is the 300tdi. |
thanks , ordered one now so will fit and see.
Have you fitted this yet? Did it work? 'Volvo XC 70, taking the rough with the smooth’
nope it didn't
| Stripygitface Member Since: 16 Sep 2014 Location: Kent Posts: 81 |
Check the dipstick tube hasn't moved when I had a 200tdi, had the oil light come on at tickover, turn out the dipstick tube had been pushed down furhter into the engine, hence dipstick level was correct, but actually engine oile level was low.
