Home > For Sale & Wanted > [For Sale] A couple of bits for sale
VVS210
In true New Years spirit I am taking a step back & looking at all the bits & pieces I have accumulated & don't need due to changes in plans.
Most of the stuff is collection only due to size & I will be putting it all up on the forum a couple of weeks in advance of the Newbury 4x4 autojumble in April as I am sure forum members will be travelling there & either for themselves or on behalf of someone who is not going but is local to them, anything not already sold to forum members will get put out for sale there.
Anyway a few smaller bits that can be posted starting with these two.
PRC3432 - fog light switch, this is the one that goes on the right hand side of the steering column on the pre Defender vehicles. I was planning on using it as an auxiliary switch to run front spot lights on a roof rack but as I have said, plans have changed & it's no longer needed. £10 plus postage.
Ignition switch & 2 keys - this was removed from my 110 DCPU as the ignition key didn't work in the door locks so I replaced them all with a paired set. This is a second hand item but was working perfectly when I removed it, all the blade connectors are intact, the steering lock plunger works & the lock turns smoothly. £25 plus £6 postage - will be sent Royal Mail 2nd class signed for.
Post #750198 9th Jan 2019 7:18pm
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
Is there bracketry on Defender steering columns (specifically Td5) for the earlier fogswitch, or does something need to be made up to attach it?
Post #750231 9th Jan 2019 9:00pm
VVS210
You should have a hole in the metal bracket in front of the wiper switch which the switch is bolted to. You will have to use a step drill or chain drill & file, a suitable hole in the plastic surround for the rubber seal, BUT, the good news is the place to drill it is clearly marked in the inside of the plastic.
Post #750238 9th Jan 2019 9:27pm
RoddyK05
Excellent, I’ll take it if you still have it. I’ll PM you my details.
Post #750258 9th Jan 2019 11:00pm
VVS210
Fog light switch sold pending the usual. Thumbs Up
Post #750279 10th Jan 2019 9:36am
HK07
England 2007 Defender 90 Puma 2.4 HT Cairns Blue
If the fog light falls thru, I would like it please, and can collect. 2007 90 Puma - Love it - Best car I have ever owned.
1989 Ninety 200tdi - Love it - Second best car I have ever owned.
1951 80" Series 1 - Love it - Third best car I have ever owned.
Post #750295 10th Jan 2019 11:05am
VVS210
2nd dibs on fog light switch to HK07.
Post #750526 11th Jan 2019 1:29pm
VVS210
Ignition lock now on eBay.
Post #750528 11th Jan 2019 1:43pm
VVS210
Fog light switch posted to RoddyK05 this morning Thumbs Up
Post #751173 14th Jan 2019 12:09pm
