![]() | Home > Maintenance & Modifications > front vents |
| tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1125
I took the vent completely off and glued the seal to the bulkhead, then ran a fine bead of clear waterproof mastic around, fits nice looks good as well .
Click image to enlarge |
well finally got round to using the defender ,they are far better than the foam ones I had fitted , hardy any draft coming in I might even fit a bit of foam to the bottom edge on the flap .
But well worth fitting the rubber type , IMO . |
| Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193
Nice, ill bear that in mind, should/when I need to replace mine
Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
| Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 683
Don’t bother with genuine Land Rover foam seals, I have had no luck with them, they don’t fit correctly and the adhesive tape becomes unbonded from the foam in hot weather.
Bizarrely Britpart pattern foam seals are superb at a fraction of the price! |
| Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 732
Tolley what glue did you use to secure the rubber seals to the flaps? I've tried replacing the foam ones and they keep water out when the vehicle is stationary but I can see daylight through the bottom corners. The water seems to run in and drips on the accelerator pedal when driving in rain at more than 60mph so keen to try the rubber variants. 2005 Td5 110 Hardtop 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
just a super glue and then a small bead of clear mastic around the edge .
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6060
It’s worth checking that the hinge isn’t bent, if the gap is that bad. |
Thanks both
| yostumpy Member Since: 01 Aug 2010 Location: n/kent Posts: 327 |
A new windscreen seal might be your next job, looking at the cracks in the corner. Lets water in , you know
| All times are GMT |
