Home > Wheels & Tyres > Bowler Spare Wheel |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7866 |
I don't think you'll have any issues. I have 16" Bowler with very similar tyre diameter with no issues. I believe the 18" are ET15 compared to 16" being ET10 but sure it will be OK.
You might want a spare wheel lock of Brendan James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
9th Jan 2019 2:30pm |
Michaelkan Member Since: 19 Dec 2018 Location: Bath Posts: 149 |
Spare wheel lock of Brendan? I’m thinking using a chain lock over it. Although I seen a padlock for spare wheel on a defender. Really neat looking lock. Anyone got a recommendation of locks? Thanks.
9th Jan 2019 2:40pm |
One that similar to this that fit bowler wheels?
Click image to enlarge |
9th Jan 2019 2:49pm |
Sorry... off Brendan the forum sponsor from 4x4overlander https://www.4x4overlander.com/product/defe...protector/
I used a soft bike lock temporarily but it wore a tiny dink in the paint The padlock type you mention, if it's the one I'm thinking of won't fit the Bowlers. James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
9th Jan 2019 2:51pm |
pjrb Member Since: 12 Sep 2018 Location: London Posts: 27 |
Wherebouts did you buy the spare wheel?
9th Jan 2019 5:56pm |
eBay.
9th Jan 2019 6:05pm |
LR Sam Member Since: 08 Nov 2012 Location: Yorkshire Posts: 226 |
from my experience 285's will hit the lights on opening the door fully. I added a spare wheel carrier (mantec) and this stopped the lights hitting issue. They were ET0 wheels
9th Jan 2019 8:27pm |
Damn. You are right. It hit the lights when fully opened. So what are my options? Does Mantec swing away solve the problem? Can anyone confirm pls? Thanks.
10th Jan 2019 2:31pm |
And do I need to get the adapter longer bolt for 285 wheels. Thanks.
10th Jan 2019 3:54pm |
The mantec sorted it for me as the wheel is bolted in a slightly different position and the arm effectively stops it. I think Mantec have gone bust though but hopefully someone should be able to tell you.
Cheers |
10th Jan 2019 4:10pm |
Mantec still around. I think flatdog carries them.
10th Jan 2019 5:41pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3747 |
18" Bowler on the rear
Click image to enlarge I can't remember if it hit the lights or not,, Did not think it did,,But i want with a Mantec carrier, mainly to sves the door hinges Click image to enlarge California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
10th Jan 2019 8:19pm |
Ordered a mantec swingaway with spacer and longer bolts. Should be sorted as long I don’t messed up with the drilling of the holes.
10th Jan 2019 8:28pm |
Finally managed to fit the bowler as a spare. For those that using mantec swingaway army version, u will need the extension and the spacer. The wheel doesn’t touch the inductor.
Click image to enlarge Click image to enlarge Click image to enlarge |
28th Jan 2019 3:13pm |
