Home > Puma (Tdci) > Sleeping in a TDCi!
Page 2 of 4 <1234>
flinty99
2007 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Somebody should have asked. I had my Jetboil. Whistle
Post #74921 8th Jun 2011 10:32pm
mse
Plenty of cheap 12v kettles...even halfords sell them.
You could even get the single cup types
Cost about �10 for the full kettle!
as for rear power, is this what you are talking about?
taken before upgrading the rear speakers Mike
Post #74928 8th Jun 2011 11:22pm
Zagato
That's what I'm looking for thanks for that. I have a simple Trangia to warm water and cook with but this allows you to stay in the vehicle if the weather isn't great and it's a lot simpler but slower.
I presume the 12V connection comes from the plug which I have just used to plug the tow bar electrics into Rolling Eyes (back of rear light!) Can you connect it from anywhere else in the back or buy some sort of double plug adaptor?
Noworries 1000 Watt thing sounds a bit pricey and professional for me just making a cuppa!
Post #74941 9th Jun 2011 7:45am
Happyoldgit
As has been covered before there's a spare power feed behind the right rear speaker housing hence it being a popular place to add a power socket.
Next question? Steve.
http://forums.lr4x4.com
Post #74953 9th Jun 2011 9:41am
JSG
As MOG says there are two wires behing the speaker panel with a perm live and earth - they are usually taped to the side of the loom and totally seperate to the towing electrics.
You can either remover the panel completely or just the speaker.
I removed the panel completely to drill a hole for the socket.
 John
2011 Tdci 110 CSW XS
Post #74961 9th Jun 2011 11:21am
Happyoldgit
^^Pretty much where I put mine too
Forgive all the dog & horse hairs and spatters of mud over the door and general non pristine appearance Zag Wink Here's a photo of where I put the rear worklamp switch too - just in case you wake up in the night with an urgent need to know Laughing
 Steve.
Post #74963 9th Jun 2011 11:50am
Zagato
Thanks for that, Are there particular sockets to get or am I just looking for a 12V socket from Halfords?
Somthing like this maybe with a 20 amp limit Confused http://www.devon4x4.com/index.php?page=sho...;Itemid=14
So I presume there is a spare wire behind each rear speaker as a rear light would be handy Thumbs Up
Post #74978 9th Jun 2011 12:52pm
DefenderOfTheEarth
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Uh oh - this is stirring rather inconvenient (while we have a young baby) camping urges... Defender 110XS SW gone... now VW California 180 4 Motion.
Post #74981 9th Jun 2011 1:04pm
Zagato
Post #74989 9th Jun 2011 1:21pm
Happyoldgit
Mine are just 12v cigarette lighter style sockets, Vehicle Wiring Products or similar will be able to supply everything you need.
http://www.vehicle-wiring-products.eu/VWP-...mepage.php
http://www.vehicle-wiring-products.eu/VWP-...12vacc.php
Don't forget we are talking Land Rover, one spare power outlet behind one speaker panel is deemed quite enough! Steve.
Post #74990 9th Jun 2011 1:21pm
JSG
From memory there is only power on the one side. I have used the 12v marine grade sockets from MSS and Mudstuff before which are standard 'fag lighter' types - I would steer clear of any cheap options.
This time I fitted a Hella type socket as they have a 'tighter' connection and I have a number of items with a Hella plug fitted. John
Post #74993 9th Jun 2011 1:28pm
Zagato
Just spoken to Devon 4x4 who said I need to find out what amp-age the existing Defender wire is capable of and suggests it would be a good idea to put a fuse in somewhere or better run a thick wire from the battery with a fuse in it Confused
I'm probably only ever going to use it for a mobile light and a kettle rated at 14 amps max Neutral
Mudstuff also don't know what the Defender wires are rated at and suggest finding out before plugging in a 14 amp kettle in.
ANYONE know Question
Post #74994 9th Jun 2011 1:34pm
Happyoldgit
I'm probably only ever going to use it for a mobile light i can just plug in and a kettle. Neutral
The spare feed is constantly live and fused, I blew mine and it's one of the fuses in the drivers seatbox. If you are going to run high draw items off the socket then yes I would run a new, fused cable direct from the battery. Steve.
Post #74998 9th Jun 2011 2:04pm
Isn't having a 12v kettle not 'camping' ?
I like the dual fuel Coleman stoves!
Post #75000 9th Jun 2011 2:14pm
iruffell
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Zambezi Silver
I have the twin burner Coleman and it will boil a litre of water in about 2 minutes, i bet those kettles take an age.
Post #75001 9th Jun 2011 3:26pm
Page 2 of 4 <1234>
