Home > Technical > Battery Life
Page 2 of 2 <12
sako243
I wouldn't but then I got 20 years out of the original battery... Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #749349 5th Jan 2019 12:54pm
SteveK
United Kingdom 2002 Defender 110 Td5 HT Rimini Red
My 2002 TD5 had the original battery until 2015 and I replaced it with a genuine LR battery as I had a discount voucher from the local stealer.
I totally drained the battery in 2016 by leaving the lights on overnight and after that (and sorting out the immobilser!) it was never quite the same and didn't like cold mornings. I replaced the battery again early last year with a YUSA and if the 110 isn't driven for a couple of weeks the voltage drops to around 11.7 and this isn't always quite enough to start it!
I recently bought a solar trickle charger to try and maintain a reasonable state of charge and I'll let you know ifit has any impact!
Post #749362 5th Jan 2019 2:40pm
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
blackwolf wrote:
Marks Landy wrote:
Hope you have a set of jump leads in the back.
Of course, always.
There are Defender owners who don't carry jump leads? Shocked
Wonder if Toyota / Jeep owners feel the need to carry jump leads around?
Post #749376 5th Jan 2019 4:24pm
Mo Murphy
I've carried jump leads around for 20+ years and only used them once on a colleagues Jeep one very cold evening ๐Ÿ˜Š
50 Shades of Pennine Grey
Post #749383 5th Jan 2019 4:48pm
I've only ever used them to help other people (although I know it is tempting fate to say so).
Post #749407 5th Jan 2019 5:47pm
kaney
United Kingdom 2005 Defender 90 Td5 CSW Epsom Green
Left mine for a day( 2008 original battery) without running over the holidays and it would'nt start the day after so i charged it overnight and started fine the day after but i will monitor it
Post #749412 5th Jan 2019 6:43pm
leeds
If thinking jump leads for a Defender make sure that the croc clips are fully insulated as the positive post is close to edge of battery box.
Anderson SB175 mounted on battery box saves opening up battery box on a Defender
35mm2 copper cables are good, be slightly wary of aluminium ones or copper coated ali
Decent length jump leads say 4.5m with croc clips one end and Anderson at other end plus short say 0.5m croc clips one end and Anderson at other end gives best of both wells.
Brendan
Post #749414 5th Jan 2019 6:46pm
sako243
Some of the Land Cruisers I've seen appear to come with two batteries as standard Laughing
Never used jump leads in my Defender, used them on the RR a few times. Ed
Post #749426 5th Jan 2019 7:25pm
Slideywindows
I've never carried jump leads, even on old Series vehicles, over many years.
Fortunately the only time I needed them, a friendly guy in a Range Rover Classic at the other petrol pump, dug out his set and got me going.
He tucked them away under all his stuff piled in the back - and I promptly stalled the vehicle! So he had to dig out his jump leads again.....
I think he let me off, as the LR concerned was built in 1948.
He did gently suggest that I "buy a battery" though.........
Back on topic, I'm having difficulty starting my petrol Ninety from cold at the moment and am beginning to suspect that a tired battery is the cause.
Following the suggestion on here I'm currently charging it, and when fully charged I will leave it for 48 hours and measure the voltage drop.
I actually hope it's the cause of the problem, as it is easy to remedy.
Post #749457 5th Jan 2019 9:03pm
I never used to bother on series vehicles, but they always had a starting handle. Many, many times did I start them with the handle, usually just because it was possible and fun to do.
Post #749495 5th Jan 2019 11:27pm
Notyalc
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Brendan
More out of curiosity than anything.....
When you fit the Anderson plug to the front of the battery box, where do you bring the cables out? Is there an issue with there being a โ€˜holeโ€™ which could potentially allow battery gas into the cab? Is a grommet sufficient or do you need glands to provide an airtight seal?
Post #749527 6th Jan 2019 10:51am
htb2
Wales
Would not worry about airtight seal, as the lids are not an airtight seal,well not on any I've owned. Grommet will do fine.
Post #749550 6th Jan 2019 1:47pm
williamthedog
As said above grommets will be fine. That's what I have done with mine. Thumbs Up
Post #749567 6th Jan 2019 3:55pm
John64
Scotland 2008 Defender 90 Puma 2.4 PU Tonga Green
I always carry jump leads in both my Landrovers just in case. If Im not using Defender for a few weeks I connect to an optimser in garage to keep fully charged.
Post #749761 7th Jan 2019 4:12pm
Page 2 of 2 <12
