Home > Puma (Tdci) > Mystery Leak
expatRob
Germany 2007 Defender 110 Puma 2.4 SW Tonga Green
Mystery Leak
Every time I put my puma on a lift I notice a small drop formed on the area circled on the attached photo. I think it is gearbox oil. I can't see where it is coming from. The oil is a nice clear caramel color though.
Any thoughts on what this is or where it may be coming from?
The drop hangs where the red circle is
Thanks
Post #748916 3rd Jan 2019 4:32pm
Dreamweapon
Scotland 2008 Defender 110 Puma 2.4 HT Cairns Blue
Hi Rob, can't see the photo. Are you sure it isn't the transfer box? There are a couple of well known potential leaky points on those. The gearbox on mine is the one thing that has never leaked Shocked.
Al
Post #748920 3rd Jan 2019 5:03pm
expatRob
I just added the photo, sorry. The drop hangs where the red circle is
Post #748971 3rd Jan 2019 8:38pm
Dreamweapon
I have exactly the same drip of oil in the exactly the same place, golden drip, lowest point of the transfer box housing. Any oil which either weeps out of the seals, inspection hatch cover will tend to gather at this point. I had a major oil leak dripping through there when the front drive output seal went, but that was frequent coin sized drips on my parking place. The inspection hatch can weep through the sealant and occasionally benefits from a bit a gentle tighten. When you refitted the drain plug last time, did you use a thread sealant like plumbers tape for instance? As oil can sometimes pass the drain plug.
Hope this helps, as usual you could just wash the transfer box drive down the A5 for a bit then stick it back on the ramp. I always considered the golden drip reasonably normal due to seals weeping oil due to thermal cycles.
I'm sure somebody will be along in a bit with another theory Very Happy
Al
Post #749172 4th Jan 2019 3:17pm
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
It is very much likely to be gearbox or transfer box oil. It almost always runs to this lowest point. You need to source the leak, follow the trail of wet oil to find it or, as said above, clean it all off really good then go for a drive and put it straight on a ramp. If you're lucky you'll see it trickling.
One quick check you can make is the adaptor shaft housing (aka Gearbox Extension Housing) which sits between gearbox and transfer box. There is a small drain hole on the bottom of this, stick your finger or blue paper towel on it and see if it's wet - if it is then it's likely to be the gearbox output shaft seal and / or transfer box input seal. Both require removal of the transfer box. Often when this leaks the air as you drive along blows the oil back and it hits the transfer box casing, then running down to the place you pictured. It can lead people to look in the wrong place.
Thanks Thumbs Up Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #749439 5th Jan 2019 8:01pm
Mcmuffin
Belgium 2013 Defender 130 Puma 2.2 HCPU Santorini Black
I had about the same problem. Took it to an experienced garagist. His answer was not to search/repair it. There is a big chance it is more leaking after the repair.
One drop is not leaking, it is “sweating”!
Kris
Post #749516 6th Jan 2019 9:07am
lohr500
It is Landrover's unique oil level monitoring system, as perfected over many years with the Series vehicles.
When the drip stops, it is time to check the oil Laughing
Post #749518 6th Jan 2019 10:04am
