Home > Technical > fuel lift pump - should I feel resistance while priming?
donmacn
Last of tonight's daft questions...
After working on the spill rail, it was harder to start the car. I assume fuel had drained back to the tank.
So, popped the bonnet and tried using the lever underneath the lift pump. It seemed to me to be doing absolutely nothing at all. I was getting a good range of movement on the lever, but no feeling of resistance at all.
Should I have felt anything at all? Or would there be nothing at all until some fuel got closer?
The car did eventually start - so no great problem - just curious really, and wondering if maybe the lift pump itself has seen better days?
Thanks Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #748975 3rd Jan 2019 8:55pm
htb2
Wales
try turning the crank, lift pump maybe on max lift on cam
Post #748976 3rd Jan 2019 8:57pm
donmacn
thanks. But wouldn't that mean I'd get a smaller range of movement with the lever?
I had read about that previously, so was expecting that maybe the lever wouldn't move too much - but it was going nearly 90 degrees, from about horizontal, to about straight down. Donald
in the past..
Post #748986 3rd Jan 2019 9:25pm
dorsetsmith
Post #748987 3rd Jan 2019 9:28pm
htb2
Wales
IIRC priming lever operates against the arm btw cam and lift pump. If arm on top of cam then pump on delivery stroke and priming lever flapping in the breeze with full movement but doing nowt.
Post #748989 3rd Jan 2019 9:31pm
donmacn
thanks both - I'm now better informed.
Just wondering further about this. If you had a problem 'on the roadside' and needed to move the camshaft, you'd need to get a spanner or socket on the crankshaft pulley?
(or move the car a short distance while in gear?)
...and the video mentions putting the lever in the 'stow' position. What would happen if you didn't? I don't actually know if I have or not, but the car hasn't moved more than 10 yards anyway, so no great harm done ... Donald
in the past..
Post #748999 3rd Jan 2019 9:49pm
htb2
Wales
Just rock in gear to turn crank, or pull tug on belts(if needs must).
I know you you should stow the primer lever but never bothered( senility)
Post #749007 3rd Jan 2019 10:00pm
donmacn
Very Happy Thumbs Up Donald
in the past..
Post #749013 3rd Jan 2019 10:04pm
