Home > Puma (Tdci) > EML light 1103 MAF sensor
mata
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
Hi there, I’ve been seeing how this issue goes, hoping it might go away but it hasn’t.
I’ve replaced MAP and MAF sensors this past year trying to resolve an underboost fault which ended up being sticking turbo veins, ultimately resolved by replacing the turbo.
Before the turbo issue I’d always had a MAF fault stored in the list but it never used to illuminate the EML but i now have a reoccurring EML for this fault only.
The MAF was replaced in summer with a brand new genuine one from Landrover. The vehicle has a superchips remap, superchips supplied K&N panel filter and a blanking plate with small hole over the EGR (which was also replaced 1 to 2 years ago with a genuine Landrover unit.
Other than putting the car back to standard and seeing how I go, which isn’t all that appealing, is there any process I can follow to try and establish why the 1103 fault code is now illuminating my EML?
Thanks in advance for you thoughts , Mat.
Post #746780 21st Dec 2018 6:51pm
It may well be the EGR causing the MAF faults as the two go hand in hand.
Is the EGR fully active or shut and fully blanked? ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #746784 21st Dec 2018 7:15pm
mata
The EGR is fully active but with a blanking plate with small hole. Should t be too hard to take the plate out and see how things go. Thanks for the suggestion.
Post #746785 21st Dec 2018 7:34pm
That may well be your issues, years ago many tried it with that method. Some had no issues, some had immodate issues and others the EML occasionally.
Mine is deleted and blanked completely, prior to that with active EGR I had no end of issues.
The EGR can throw out MAF readings hence metering of airflow May throw a DTC.
These are possibilities at least.
Good luck.👍🏻 ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #746790 21st Dec 2018 8:19pm
mata
Thanks again, I’ll give t a go, I thought fitting a brand new genuine egr with the blank with hole might be a lasting solution but I was forgetting I was working on a Defender!
Post #747092 23rd Dec 2018 8:38pm
expatRob
Germany 2007 Defender 110 Puma 2.4 SW Tonga Green
1103 nightmare
I too am battling the 1103 fault nightmare.
I have the standard map, no tuning.
I have a new OEM MAF sensor, I have a NEW EGR (no blank or small hole blank - i used too but had it removed when the new EGR went in.) My EML will stay off for a few days and then it will light up again. I don't know what to do.
I also have the under-boost problem. I'm sure it is also the Turbo Veins sticking. Is there anything worth doing to fix this or is a new Turbo the only option.
Thanks
Rob
Post #748910 3rd Jan 2019 3:52pm
mata
Regarding turbo veins, take the actuator arm off the actuator by removing the (easy to lose) circlip. Move the arm up and down and feel for any sticking. Mine was sticking at the top (versus gravity) end, it took a lot of force to get it moving again. Ive more information in another thread somewhere, have a look for it.
I believe you can get your turbo repaired - they replace the vein mechanism but given min ehad done 140K miles i felt it prudent to replace the whole unit with a recon one.
Post #748911 3rd Jan 2019 4:03pm
expatRob
Thanks I will take a look at the Actuator arm.
When I am driving on the highway at speed and the then the engine loses power and the 6th is worthless, I pull to a stop, turn off the engine and then turn back on. It fixes the problem. Obviously I can't just do this all the time, I need to find out what to do.
Post #748913 3rd Jan 2019 4:24pm
mata
This was my symptom also, it got progressively worse over a few months.
Post #748965 3rd Jan 2019 8:08pm
