Home > In Car Electronics > Voltage increase
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Voltage increase
Installed the Webasto air top and as a precaution I ran a multimeter across the aux battery whilst it was running ang got 12.14v
When I switched it off and it ran through it’s shutdown cycle, the voltage began to increase up to 12.38v.
My set up is;
Main battery > VSR > Aux battery > Aux fuseboard > Webasto, lights, sink etc.
Is the increase due to power being drawn from the main battery?
I understand the vsr allows power from the main battery\ alternator when 13.8v is registered to pass to the aux to charge it, so I’m not expecting an increase in voltage from the main battery.
Is it just the battery voltage setting when it has no draw on it?
Post #748733 2nd Jan 2019 6:01pm
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
I'd say that it settling is a fair guess. You'll find batteries move around a bit like that. If you left it all running you probably would have found the battery would increase/recover its voltage even at the same current draw too.
Post #748741 2nd Jan 2019 7:00pm
Badger110
I was hoping that'd be the case.
My only fear is the aux battery is drawing power from the main starter battery, which i don't want!
Post #748813 2nd Jan 2019 11:04pm
leeds
A 12 volt battery showing a rested voltage/no load showing 12.38 volts is about 70-80% fully charged. OK it does depend on the accuracy of the volt meter
Now a light load on a 12volt battery will drop the apparent battery voltage by about 0.3 volts, whilst a heavy load could drop the apparent battery voltage by around a 1 volt plus.
Once the load is removed the voltage of the rested battery will rise to represent its state of charge. which on your figure is about 70-80% charge.
Hope that makes sense.
Brendan
Post #748835 3rd Jan 2019 12:33am
Badger110
Cheers Leeds Thumbs Up
Post #748845 3rd Jan 2019 7:50am
