Home > Puma (Tdci) > Puma half shafts - Britpart part number?
stuart123
United Kingdom 2009 Defender 90 Puma 2.4 CSW Aintree Green
Hi all. I’m looking at changing my rear half shafts for one piece Britpart ones. Question is, are these the right ones?
Is there anything else I need or should it be a simple change over?
It’s an 2009, 90. Thanks!
Part numbers: LR072977 & LR072976
Post #748429 1st Jan 2019 9:56am
They certainly look like the right ones.
When I changed over to one piece shafts recently, I also replaced the bolts with galvanised, 10.9 cap head bolts and matching spring washers, all torqued to 65Nm. Oh, and new paper gaskets. All of those bits came from eBay for a few pounds.
 Darren
Post #748441 1st Jan 2019 11:20am
hornet
Re: Puma half shafts - Britpart part number?
I strongly recommend taking an enhanced version (HD) from a quality manufacturer. Otherwise the shafts will wear quickly again...
Post #748713 2nd Jan 2019 3:52pm
@LandroverAnorak...
Yours looks like a 110? were they genuine LR shafts or aftermarket ones? If so, what ones did you go for? (90 & 110 are different strength I believe)...
Post #748739 2nd Jan 2019 6:56pm
They're genuine ones. I was lucky enough to find a bargain on eBay. Darren
Post #748773 2nd Jan 2019 9:02pm
Vitesse
Hi. I have another thread going on this but it’s all the same thing really. This is intereting stuff and what I need to know is there any reason why I shouldn’t buy the Britpart one piece half shafts for my 2015 90. Just used normally on the roads etc... has anyone broken these units supplied by britpart ? Are they known to be weaker ? Thanks for any help 👍 2015 90 XS Santorini Black
Post #748781 2nd Jan 2019 9:31pm
stuart123
Thanks all.
I think I’ll go down the Britpart route. For my use, they should be fine and a whole lot better than the currrnt ones that have done 90k miles as far as I know...!
Am I right innsaying it’s a straight swap, unbolt, slide out and new ones in?
No oil etc is going to come out etc?!
Post #748786 2nd Jan 2019 9:46pm
htb2
Wales
Jack up the side your changing till its above level, leave for 10 mins, undo bolts pull shaft. minimal oil loss
Post #748790 2nd Jan 2019 9:54pm
In the pictures above, I jacked up one side at a time and didn't loose any oil. It's a very easy job. Just make sure that the gasket mating faces are clean and that the bolts are torqued up correctly. Darren
Post #748800 2nd Jan 2019 10:18pm
I think the only problem is that they haven't been around for very long so there's very little info to go on yet. Darren
Post #748801 2nd Jan 2019 10:19pm
I think the only problem is that they are supplied by Britpart! They'll probably have five bolt-holes instead of six, or 23 splines instead of 24, or be an inch too long, at least if my (thankfully and intentionally limited) experience of Britpart is anything to go by.
I still can't forgive them for the hub nut that destroyed my stub axle.
Post #748826 2nd Jan 2019 11:38pm
^^ I hope they have 5 bolt holes Rolling with laughter
But agree with the rest!
Post #748844 3rd Jan 2019 7:50am
Oldowner
Why not just put in a pair of 300tdi disco half shafts? Most breakers wil have stacks of the things at next to nothing, My 08 Puma has had them for years with no issues and complete lack of driveshaft backlash
Post #748848 3rd Jan 2019 8:04am
Doh! I meant to say "six holes not five". That went well! Rolling with laughter
Post #748859 3rd Jan 2019 9:55am
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
I have been running britpart ones since June and have done approx 5000 miles including a few hundred towing. I can thoroughly recommend them. They have transformed the driving.
More info including photos here: https://www.defender2.net/forum/topic60317-15.html
Post #748862 3rd Jan 2019 10:33am
