![]() | Home > Technical > Rear shock washer orientation |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 ![]() ![]() ![]() |
Yes you're right, the domed surface goes against the rubber bush, otherwise it 'cups" the bushes against the mount and seriously restricts the flex, end result, the top of the shocker canister flexes instead where the bolt is welded on which breaks off after a while. (Don't ask me how I know
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 ![]() ![]() ![]() |
Great! Just waiting for my new shock turrets before I can get the fronts in.
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
Is that blood on the new shock in the 2nd picture? Knuckle rash today perhaps?
Haha! No its the waxy anti corrosion stuff i put on my nuts and bolts. Ardrox AV30 if you want to know exacty what it is. Must have caught it with the brush, just havent wiped it off yet.
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
I also did this job yesterday. Bit of a mind boggle getting all the cups the right way around. The fitting instructions were as much use as my 1 year old.
![]() Click image to enlarge ![]() Click image to enlarge 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20820 ![]() ![]() |
The top mount washer on the rear has the curved side towards the chassis and the flat side out toward the nut.
![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Didn't you contemplate changing the turrets when you changed everything over? The top is a lovely water trap on the standard turrets. When I done mine I fitted D44 h/d turrets. No rust traps. ![]() Click image to enlarge |
I did contemplate it yes. I just thought I’d assess the condition of the standards and for 7 years old living in Cornwall they were pretty good. Will change them at some point. Probably when I upgrade the springs. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
I have D44 turrets too, in Matt black. They are very good combined with the HD turret rings.
As mentioned above worth thinking about at a later date. ![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
