Lift pump
Hello again, I have purchased a new fuel lift pump. The new part has come with a spacer and there is a clear warning which slightly confuses me. It tells you to use the original spacer from the old unit however provides a new spacer. Looking at the engine, a D1200tdi, there does not seem to be a spacer between the fuel pump and the engine. Any advice on wether to use the provided spacer please?
Click image to enlarge1990 200tdi conversion 90
27th Dec 2018 9:40pm
Alex1976
I removed my lift pump a couple of months ago as I replaced it with an electric lift pump. There was definitely no spacer in there, just the pump bolted straight to the block. I took off a genuine part, I do wonder if aftermarket parts need a spacer?
27th Dec 2018 9:59pm
dorsetsmith
lift pump on 200tdi is common to all the earlier 2.5 diesel engines, some need the spacer & some [200tdi] have it built in see below
27th Dec 2018 11:17pm
dioliahary
That’s great advice thanks.1990 200tdi conversion 90
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
