![]() | Home > Maintenance & Modifications > Screwed up whilst screwing in, now can't screw out! |
Mole grips on the back, get the screw out, retighten existing rivnut, halfords have cheap riv nut tools that will do. Original Member Pie n Pea Club.
110 HCPU Tipper |
Odin Member Since: 29 Apr 2011 Location: Aberdeenshire Posts: 237 ![]() ![]() ![]() |
Cheers Willy.
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1862 ![]() ![]() ![]() |
Hold the back of the rivnut with pliers - not too tight or you risk distorting it, unsrew bolt, gently retap with 2nd taper tap, then either reset with tool, or 3 flat washers and a new bolt with grease, hold back of rivnut and reset with spanner.
Good luck! Keith |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472 ![]() ![]() ![]() |
Yes, don't squeeze the rivnut too tight or it will clamp onto the bolt even tighter. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
