Home > Maintenance & Modifications > Duralac or ACF50 Corrosion Block ?
MJN110
United Kingdom 2016 Defender 90 Puma 2.2 Landmark LE Montalcino Red
I have been using ACF50 Corrosion Block on my fasteners for some time now but I understand there is a product called Duralac available as well.
What are your views on these products do they both do the same job or are there some applications when one is better than the other?
Thanks 2016 Defender Landmark 90
2005 Defender CSW TD5 90XS
Post #746999 23rd Dec 2018 7:59am
discomog
Whilst you're considering Duralac as an alternative to ACF50, I would also consider Tefgel. Both Duralac and Tefgel have been used in the boat industry for years particularly where aluminium parts, such as masts and booms are used with stainless steel fittings. Tefgel seems to be more expensive but Tefgel is not quite as messy as Duralac and doesn't set hard like Duralac.
Tefgel seems to work better with close fitting joints and Duralac with more loose, gappy joints. I favour Tefgel for fittings on the Defender. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #747010 23rd Dec 2018 10:22am
Greg4427
Australia 2015 Defender 90 Puma 2.2 SW Montalcino Red
I spray my Daisy, Defender 90, every six months everywhere with ACF50 and haven’t had any problems as yet. Admittedly, we don’t have the corrosion problems with our vehicles that occur in Europe.
Post #747011 23rd Dec 2018 10:43am
leeds
There are several products in the market place with anti corrosion properties, anti stick properties, or combination of both properties.
Anti corrosion properties is required when two differing metals are in contact and they are in different places on the galvanic table. Throw in water especially salt water ( close to sea or winter time with salt grit on the road) and have an electrolyte and potential galvanic cell.
Duralac has anti corrosion properties and will harden with exposure to air.
ACF 50 I believe was designed for the military as an anti corrosion spray, as a spray it is good for large areas such as rear cross members (which reminds me must do ours).
Use of plastic washers or thin rubber gaskets can also help.
Using stainless steel nuts and bolts there can be the issue of cold welding or galling of the stainless steel. Duralac has no anti seize properties. The paste supplied by Nakatanenga with their stainless bolt kits have both anti seize and anti corrosion properties. This paste is non drying.
Like many things it is a case of picking the right tool for the job in hand.
Brendan
Post #747015 23rd Dec 2018 11:18am
discomog
If you are using stainless threaded fasteners then you need to prevent or reduce galling between the nut and the bolt. If you are using stainless fasteners which come into contact with dissimilar metals then you also need a product that will prevent galvanic corrosion as well as galling. If you are using stainless washers and they come into contact with dissimilar metals then you will need a product that will prevent galvanic corrosion. Defender 90XS SW
Morgan Plus 8
Post #747021 23rd Dec 2018 12:22pm
Romadog
A good dose of copper slip then Whistle Thumbs Up
Post #747050 23rd Dec 2018 3:29pm
leeds
Copperslip is good as a lubricant but is also a good electrical conductor.
Pick the paste to do the job required.
Brendan
Post #747052 23rd Dec 2018 3:41pm
MJN110
Just for clarity gents when I was referring to ACF50 i meant the grease not the spray.
I do use the spray as well on screw heads underneath cappings and the rear cross member.
Post #747054 23rd Dec 2018 4:20pm
lohr500
I'm going back many years now, but a friend of mine did a nut & bolt restoration on his Lightweight, including fabricating many of the panels from scratch.
He used Denso Paste as a barrier between all dissimilar metals.
Many years later, there was no obvious sign of any electrolytic corrosion around the fasteners, or where steel had been bolted to ali.
No idea if it was the right stuff for the job, but the results were impressive.
Post #747057 23rd Dec 2018 4:35pm
Kev1969
United Kingdom 2003 Defender 90 Td5 PU Caledonian Blue
Duralac for me ,a bit messy but well used in the marine industry and boat building industry. A tube goes a long way .
Post #747090 23rd Dec 2018 8:33pm
