![]() | Home > Maintenance & Modifications > Seat rails |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4316 ![]() ![]() ![]() |
If you are feeling handy it is incredibly easy to make your own out of some box steel. All you need is some 40mm box steel off eBay, hack saw, a drill, 4 nuts and bolts and some black paint. 2007 110 TDCi Station Wagon XS
Since you are not a million miles away from our warehouse in Halifax, why not pop across and see what 4x4overlander has to offer.
Brendan |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 403 ![]() ![]() ![]() |
I have a couple of sets of the Mud UK ones, at 6'1" with longish legs and a few pies under the hood it is one of the best things to do to a car, my legs are comfortable and my belly isn't chafing the wheel. Only really works in a vehicle with no internal bulkhead, but in my two 110SW it is magic. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562 ![]() ![]() ![]() |
MUD rails 👍🏻
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4807 ![]() ![]() ![]() |
Lordackers I have the ones from Brendan at 4x4overlander pop over and see him for great products and brilliant customer service just don’t ask for a discount
![]() 2008 SVX 90 2000 XS TD5 90 |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1067 ![]() ![]() ![]() |
I've a set of unwanted Mudrails in the garage. They're your's for £25 plus postage.
They've been used for nearly 10 years. No longer needed as I was able to modify the new seat to move it back without rails (I wanted extra head room). They're a bit marked, but nothing that affects their function. Let me know if you'd like a photo (PM would be best). They're highly recommended if you have the standard seats. |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2380 ![]() ![]() ![]() |
I've used and been very happy with Mud rails.
Orangesofa Member Since: 10 Oct 2014 Location: Somerset Posts: 214 ![]() ![]() ![]() |
I would have to partially disagree. ![]() When I still had a full bulkhead I used the Mud rails to give me more leg space and then later used the Mud Bulkhead bar to reduce the height of the bulkhead to give me more recline so that now I have the best of both. Just using rails with a full size bulkhead is definitely an improvement but to get the full benefit - the bulkhead needs to at least be reduced in height. Phil |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 736 ![]() ![]() ![]() |
I have fitted seat extender rails - they are great. However be aware that they raise the seat height as well.
I believe that Leed's rails have less effect on height if this might be an issue for you. The raised seat height has never been a problem for me though. |
Standard seat rails risers raise front and back of the seat by about 30mm and allow 50 mm movement further backwards.
4x4overlander do both the standard type seat rails and the low line type. Lowline raise front of the seat by about 5mm and the back by about 30mm and allows 50 mm movement further backwards. Now I have never really notice back of seat being raised by about 25mm with respect to the front. If anyone experiences front of seat base catching back of thighs this type of seat rail might help. With standard seat rails there is 30mm less space between thighs and steering wheel. If of larger thigh statute then smaller steering wheel will help as they are typically 2”/50mm smaller in diameter. HTH Brendan |
Rkcorry Member Since: 23 Jan 2017 Location: Northern Ireland Posts: 227 ![]() |
I’ve got a set of mud rails going spare. In great used condition. No bolt to attach the rails. Though easily sourced.
Available for a 35.00 donation to the def2 site. As postage is considerable due to weight. [imc]https://www.defender2.net/gallery/albums/userpics/21416/normal_813E1FD8-90B4-4961-84BF-26C632884CC2.jpeg[/img] |
strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1401 ![]() ![]() ![]() |
Thats why I chose Brendan's option - much better for me personally. Euro-Leafing to infinity and beyond..... |
