Home > Td5 > Play in clutch pedal |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2557 |
If it’s the later type of pedal box with the travel limit screw rather than the rest stop screw then unfortunately it will always have more okay in the pedal. On the older type you could adjust the stop screw to ‘pre-load’ some of the play out of the linkage & rod but on the later type it’s always held at full extension by the spring. I suppose one could drill/tap the pedal box for a stop screw.
On mine there is some play in the trunnions on the end of the clutch lever, which accounts for a good half of the ‘free play’ in the pedal. If you very carefully depresss the pedal you can feel the play taken up in that bit first, before the pressure of the piston is felt. All assuming no hydraulic issues of course. |
21st Dec 2018 9:38am |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2280 |
Yes you are right, you can feel the actual free play which is only about 1cm then there’s 2 cm “lost motion” in the hydraulics before it starts to operate the clutch.
I will adjust it and see how l get on. Master/slave cylinders were renewed some time ago. Well, 50,000 miles ago to be accurate. No leaks though. |
21st Dec 2018 9:55am |
